lowering spring???????
Old Apr 1, 2007 | 06:35 PM
trustnoone7935's Avatar
Default lowering spring???????
Man this is gonna seem like a noobie question but just want to be sure,got skunk2 lowering springs,2 are kinda short and fat and 2 are kinda tall skinnywhich are the front,which are the rear.Belive me i've already searched,don't want to be flamed .TIA
Old Apr 1, 2007 | 07:12 PM
EF2_Sedan88's Avatar
Default Re: lowering spring??????? (trustnoone7935)
they should have the part # on them if soo go to the skunk2 web site and from there u will be able to tell which is which
Old Apr 1, 2007 | 07:42 PM
Default Re: lowering spring??????? (EF288Gsr)
I've got the part#,been to the web site it doesn't help.I was told the shorter fatter ones go on the front.I don't know though.
Old Apr 2, 2007 | 06:53 AM
bump cause no ones gonna help,37 people done looked but noboby can answer
Old Apr 2, 2007 | 07:01 AM
boosted_ejcivic's Avatar
the skinny ones i belive go to the front and the fat ones are for the back................
i think but i could be wrong
Old Apr 2, 2007 | 07:05 AM
EFOSV.'s Avatar
Default Re: (boosted_ejcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted_ejcivic &raquo;</TD></TR><TR><TD CLASS="quote">the skinny ones i belive go to the front and the fat ones are for the back................</TD></TR></TABLE>
Old Apr 2, 2007 | 07:40 AM
thanks for replying,but here's my problem i just called skunk2 and they said the short fat ones are for the front.But i can't get the rubber cap to fit.If i don't use the rubber cap they fit but they seem like they would not seat right because the back of the studs in the metal cap.tried to explain the best i could,lol
Old Apr 2, 2007 | 09:14 AM
misha's Avatar
Default Re: (trustnoone7935)
fat ones in the front, thats correct. I am not to sure what rubber cup you r talking about, but when i was puttign springs into my buddys EK we couldnt get those rubber pieces to fit in the back, so we took it to the shop and they just used their compressor to do it and it was fine.
Old Apr 12, 2007 | 08:07 PM
da_dude's Avatar
So the shorter one goes in the front and the longer one goes to the rear? Skunk2 are guy for not have instruction at all.
Old Apr 12, 2007 | 08:09 PM
crazykamper's Avatar
good luck! lets see some pics when you install them!!
Old Apr 13, 2007 | 03:28 PM
janz3n's Avatar
Default Re: (crazykamper)
long ones in the front.. short ones in the back.. or the ones easiest to compress with your weight in the back.. the stiffer ones go in the front because theresmore weight in the front.
DB1_559
Suspension & Brakes
May 18, 2008 03:27 PM
LeArN2LiVe
Sep 5, 2007 08:29 AM
AllMotorRP
Honda S2000
May 25, 2007 08:09 PM
g2turbo
Suspension & Brakes
Mar 16, 2007 10:58 PM
wifesaynogo
Nov 30, 2004 09:22 AM
