hit abs in rain = SNAP
Old Apr 1, 2007 | 06:09 PM
yOnKiNaToR's Avatar
Default hit abs in rain = SNAP
here's the deal guys. i'm driving down the road when the guy in front of me jacks his brakes, i do the same and abs kicks on b/c i have **** tires. anyway, i then hear a loud *** clunk/snap sound. and the car is pulling like crazy to one side. everytime i shift it clunks and pulls to one side.so i drive it to the nearest place to pull over with lights and as i'm going i hear 1 or 2 metal pieces fall off my car and onto the ground.
i jacked the car up with the **** *** scissor jack and the suspension looked ok. i wasn't losing tranny fluid and the axles seemed ok.
any of ideas what to look for?
Old Apr 1, 2007 | 06:30 PM
ludesterS's Avatar
Default Re: hit abs in rain = SNAP (yOnKiNaToR)
check your sway bar end links, also check for any cracks on the weld in the engien bay around the shocks. you may wanta try takeing a look at all 4 calipers.
Old Apr 1, 2007 | 06:32 PM
ludesterS's Avatar
if its all good then you could of messed up your diff...
Old Apr 1, 2007 | 06:35 PM
RaysBoomBoomLude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yOnKiNaToR &raquo;</TD></TR><TR><TD CLASS="quote">here's the deal guys. i'm driving down the road when the guy in front of me jacks his brakes, i do the same and abs kicks on b/c i have **** tires. anyway, i then hear a loud *** clunk/snap sound. and the car is pulling like crazy to one side. everytime i shift it clunks and pulls to one side.so i drive it to the nearest place to pull over with lights and as i'm going i hear 1 or 2 metal pieces fall off my car and onto the ground.
any of ideas what to look for? </TD></TR></TABLE>
If its pulling to one side, It sounds like a stuck caliper.
also, check your axles.
also, ABS units DO break.
Old Apr 1, 2007 | 06:40 PM
yOnKiNaToR's Avatar
Default Re: hit abs in rain = SNAP (ManBearPig)
i checked up and all around the shocks and springs. they seem ok.
it pulls a little to the left, but as soon as i let off the gas it jerks violently to the left. i'm assuming it's the axle. i did leak quite a bit of grease out of the cv shaft awhile back before i fixed the boot. this leads me to believe that maybe the cvs are messed up. anyway to check for broken axle without dissembling the damn thing?
Old Apr 1, 2007 | 06:52 PM
yah, turn lock to lock.
and if it pops, its busted
Old Apr 1, 2007 | 07:24 PM
InvaderTrax's Avatar
Lift your two front wheels off the ground and try and wiggle them side to side and up and down. Last car I saw with a problem like yours, it was a bad ball joint
Old Apr 1, 2007 | 07:28 PM
yOnKiNaToR's Avatar
Default Re: (InvaderTrax)
all my balljoints are brand new.
the nuts and bolts that fell off the car while i was driving worry me. especially since i couldn't find any evidence of something missing a washer, nut, or bolt.
i'll check the axles in a few days. thx guys
Old Apr 1, 2007 | 07:38 PM
M@'s Avatar
M@
Default Re: (yOnKiNaToR)
The axle dosen't make sense if the problem happens during braking and accelerating. It sounds more like suspension. What happens when you go to reverse, and then brake hard?
Maybe its the radius rod bushings. That would be my first guess.
Good luck, and be carefull if you are driving.
Old Apr 2, 2007 | 06:29 AM
Mykizism's Avatar
sounds like a broken differential to me..
Old Apr 2, 2007 | 04:09 PM
yOnKiNaToR's Avatar
Default Re: (Mykizism)
it only pulls hard on acceleration. and i notice that the passenger side cv shaft near the tranny wobbles. i put the car on jackstands and ran the car in 5th gear and noticed the wobble. it also makes a clunky sound near the tranny or the drivers side axle. also, i can fee a vibration through the drivers side cv shaft when the car is in gear and at speed.
what should i do guys? i'm gonna put some tranny fluid in to see if that's causing it. and then maybe replace the cv shaft first?
Old Apr 2, 2007 | 05:06 PM
sskyr32's Avatar
sounds like maybe you fragged your wheel bearing? Also, check the control arms, and like everyone else says, cv's
Old Apr 2, 2007 | 05:54 PM
yOnKiNaToR's Avatar
Default Re: (sskyr32)
oh man, i just found out why the huge pull. i sheared off the front of my radius rod . i didn't notice it because the underbody splash guard was covering it. the washer and the nut are the parts that fell off the car while i was driving.
hopefully this will clear up the axle problem. time to start checking out radius rod prices.
Old Apr 2, 2007 | 05:57 PM
Mykizism's Avatar
http://www.hondaautomotiveparts.com
Old Apr 2, 2007 | 06:00 PM
jdmlude5
Guest
Posts: n/a
Default Re: (M@)
i have done that before also.
Old Apr 2, 2007 | 06:29 PM
yOnKiNaToR's Avatar
Default Re: (jdmlude5)
you've sheared your radius rod before? did it eff up your cv shafts?
screw hondaautmotiveparts. i'm gonna buy one off someone on h-t
ANYBODY GOT A RADIUS ROD?
Old Apr 2, 2007 | 10:46 PM
hu's Avatar
hu
I do. I replaced my crossmember & radius rods with a PFIspeed traction bar. Just pm me and let me know what side you need.
FA All Day
Honda Civic (2006 - 2015)
14
Jun 11, 2008 07:07 PM
NguyenDC2
May 15, 2007 05:36 PM
nm_Civic_DrVr
Dec 27, 2006 09:51 AM
ghuynh
Nov 10, 2006 12:51 PM
kikwear002
Sep 16, 2004 11:24 AM
