some help please!!!
Old Nov 10, 2006 | 11:34 AM
ghuynh's Avatar
Default SOME HELP PLEASE!!!
whenever it rains or if the road is wet, if i brake a little too hard then my pedal would kinda bounce. the weird thing is that when that happens my whole front end makes really weird noise(like a lot of clunking noise) then my abs motor would like make a grinding noise. I really am stuck here. please help.
if anyone can help, please and thanks
Modified by ghuynh at 12:52 PM 11/10/2006
Old Nov 10, 2006 | 12:01 PM
Tizight's Avatar
Umm ABS?
Old Nov 10, 2006 | 12:16 PM
Honda Hick's Avatar
Default Re: (Tizight)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tizight &raquo;</TD></TR><TR><TD CLASS="quote">Umm ABS?</TD></TR></TABLE>
Yea, that pretty much sounds like normal ABS.
Are your tires **** and you slide alot?
Old Nov 10, 2006 | 12:27 PM
ghuynh's Avatar
well yeah but what good is abs then if it slips so bad
Old Nov 10, 2006 | 12:40 PM
Honda Hick's Avatar
Default Re: (ghuynh)
It's not going to work correctly if you have worn tires. The only thing that's going to stop you with real bad tires is a telephone pole.
Old Nov 10, 2006 | 12:51 PM
Sam92Teg's Avatar
Default Re: SOME HELP PLEASE!!! (ghuynh)
And if your hearing grinding noises, check your brake pads.
nvynuke18
Honda Civic (2006 - 2015)
Apr 12, 2009 03:22 PM
NguyenDC2
May 15, 2007 05:36 PM
nm_Civic_DrVr
Dec 27, 2006 09:51 AM
SIcivicHATCH
31
Apr 7, 2005 08:00 AM
seifer
Feb 19, 2005 06:02 AM
