boost question
From: ON A STREET NEAR YOU BREAKING TRACTION ON ALL 4 WHEELS!
ok i was wondering that if i used dsm 450 injectors.... i would need a resistor box.... if i go higher than 450's would i need the resistor box as well? and how much are resistor boxes?
Depends on what kind of injectors, peak and hold or saturated injectors. Peak and hold require you to wire resister boxes to them. Your dsm 450s are peak and hold.
DSM injectors need either resistor box (cleaner look) or resistor packs to work. I have a resistor box for sale if your interested.
RC injector i believe from 310 to 500 are plug and play and everything after require a box.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid »</TD></TR><TR><TD CLASS="quote">RC injector i believe from 310 to 500 are plug and play and everything after require a box. </TD></TR></TABLE>
Not true. I'm running saturated RC 750's.
You'll need a resistor box for DSM 450s, but thay can be had for $30-$40 or you may be able to find them at a junk yard... They come on the old EF Civic Si's and DSM's
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostedb20EH2 »</TD></TR><TR><TD CLASS="quote">Depends on what kind of injectors, peak and hold or saturated injectors. Peak and hold require you to wire resister boxes to them. Your dsm 450s are peak and hold.</TD></TR></TABLE>
ok.. sorry to bring this back from the dead... would i need a resistor box if i used 550cc injectors? or do i just need the resistor box for only dsm 450's?
ej1serge
Mar 14, 2012 11:33 PM
MysteryWagon
Jun 17, 2005 04:16 AM
