dpfi to mpfi diaster
I have a 1990 CRX i doing a the swap did all the wiring that were on all instructions. I able to start the car but it is misfiring, idles like s*** and running very rich. One wire on the EAVC is not hooked up but if you do hook up the wire WOT what is causing this? I have an SAFC but not hooked up right not and running a skunk2 mani. Any help would be godly.
Thanks
Thanks
i got the swap completed now but i am still running the SI mani. I want to use the skunk2 mani but i have a problem with the idle going to around 3k and then cutting off and throwing a code 3 (map). Th only thing I can think of is that I need to unplug my map sensor on the firewall and connnect it to the EG tb. Has anyone done this before? Thank you guys for all your help!!!
Chris Dodd
Sep 10, 2013 12:28 PM
