where can I get a block of aluminum?
I tryed the local machine shops, suppy houses and noone has a block of aluminum, I need like a 6" L x 6" W and 3" H block, Any ideas where I can get one? Thanks guys!!!!
Thanks guys!! Does it sound right to pay 200 bucks for a little block of aluminum? Thats how much all the places are charging that you's posted, I was on earl's website and they were using a mason's chisel and a block of aluminum to cut braided stainless steel hose. Thought it would be intresting to cut hose like that, I already have a chisel but no aluminum, Would lead work? Again thanks guys!
yeah, its expensive..
on a budget? do this.
go on ebay. (not ebay motors)... haha
type in aluminum
tons of weird cutoffs will come up. i got a piece for a velocity stack setup i'm making (baseplate of a manifold), that would be about 150 from a supplier, for 19 dollars plus 12 shipping.
WOOT
good luck...there are usually lots of weird sizes up there, many in your size-range when i bougut mine a few months ago
type in aluminum
WOOT
Thanks alot!!! Found what I need for 30 bucks!!! Im not really on a budget just like trying new things but not spending tons of money to find out it don't work, Anyways thanks! Would have never thought ebay would have it!! lol
The other place to get it cheap - bigger machine shops. They normally sell their scrap for a fraction of the virgin metal cost, and if you get the right place, they'll sell (or give) it to you for what they'd otherwise get for it.
A place I did some work for did lots of die plates, so I have more odd-sized 1/8" plates of aluminum and magnesium than I know what to do with.
Oh no! Im using to it lay the hose on to cut it with a chisel, Since the aluminum is soft it will allow the chisel to cut completely thru the hose, Also its the cleanest cut I had ever seen, NO tape needed!
http://www.youtube.com/watch?v=aDSozy6MZto
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hondatuner88 »</TD></TR><TR><TD CLASS="quote">Oh no! Im using to it lay the hose on to cut it with a chisel, Since the aluminum is soft it will allow the chisel to cut completely thru the hose, Also its the cleanest cut I had ever seen, NO tape needed!
http://www.youtube.com/watch?v=aDSozy6MZto</TD></TR></TABLE>
lol...genius!
That would have saved me a lot of time, since I just normally use my dremel.
lol...genius!
safedriver
Feb 20, 2011 02:28 PM
