where can I get a block of aluminum?
I tryed the local machine shops, suppy houses and noone has a block of aluminum, I need like a 6" L x 6" W and 3" H block, Any ideas where I can get one? Thanks guys!!!! https://honda-tech.com/forums/images/smilies/emthup.gif https://honda-tech.com/forums/images/smilies/emthup.gif
Re: where can I get a block of aluminum? (Hondatuner88)
mc master-carr has just about everything.
Re: where can I get a block of aluminum? (tharptroy)
alcoa.
Re: (Boostwerks.com)
Thanks guys!! Does it sound right to pay 200 bucks for a little block of aluminum? Thats how much all the places are charging that you's posted, I was on earl's website and they were using a mason's chisel and a block of aluminum to cut braided stainless steel hose. Thought it would be intresting to cut hose like that, I already have a chisel but no aluminum, Would lead work? Again thanks guys!
Re: (Hondatuner88)
yeah, its expensive..
on a budget? do this. go on ebay. (not ebay motors)... haha type in aluminum tons of weird cutoffs will come up. i got a piece for a velocity stack setup i'm making (baseplate of a manifold), that would be about 150 from a supplier, for 19 dollars plus 12 shipping. WOOT good luck...there are usually lots of weird sizes up there, many in your size-range when i bougut mine a few months ago |
Re: (redzcstandardhatch)
Thanks alot!!! Found what I need for 30 bucks!!! Im not really on a budget just like trying new things but not spending tons of money to find out it don't work, Anyways thanks! Would have never thought ebay would have it!! lol
Re: (Hondatuner88)
The other place to get it cheap - bigger machine shops. They normally sell their scrap for a fraction of the virgin metal cost, and if you get the right place, they'll sell (or give) it to you for what they'd otherwise get for it.
A place I did some work for did lots of die plates, so I have more odd-sized 1/8" plates of aluminum and magnesium than I know what to do with. https://honda-tech.com/forums/images...s/emsmilep.gif |
Let me get this straight...
Your going to be making your own braided hose? https://honda-tech.com/forums/images...s/emsmileo.gif |
Oh no! Im using to it lay the hose on to cut it with a chisel, Since the aluminum is soft it will allow the chisel to cut completely thru the hose, Also its the cleanest cut I had ever seen, NO tape needed!
http://www.youtube.com/watch?v=aDSozy6MZto |
Re: (Hondatuner88)
wow, thats a great way to do it...great how-to
Re: (Hondatuner88)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hondatuner88 »</TD></TR><TR><TD CLASS="quote">Oh no! Im using to it lay the hose on to cut it with a chisel, Since the aluminum is soft it will allow the chisel to cut completely thru the hose, Also its the cleanest cut I had ever seen, NO tape needed!
http://www.youtube.com/watch?v=aDSozy6MZto</TD></TR></TABLE> lol...genius! https://honda-tech.com/forums/images...es/emsmile.gif https://honda-tech.com/forums/images/smilies/emthup.gif That would have saved me a lot of time, since I just normally use my dremel. |
That is good info I just used an angle grinder with a cutoff wheel.
