bleeding brake lines.
Old Mar 31, 2007 | 05:35 PM
dank24's Avatar
Default bleeding brake lines.
I got air in my lines when trying to bleed my rear calapers. Is their a master valve That I should bleed while adding dot 4 brake fluid? Or just bleed the same line I was earlyer?
how many time should i press the peddle? I only have 2 small bottles of brake fluid. An how do you bleed them? Just pump the pedal? I got told to pump it a few times then hold it down.
This is also in my 05 ep3
Thanks in advance
Modified by dank24 at 6:47 PM 3/31/2007
Old Mar 31, 2007 | 06:05 PM
dank24's Avatar
anyone? Need some help guys. I gotta fix this by 8am tomorrow haha
Old Apr 1, 2007 | 12:33 AM
Rev4Ever's Avatar
Default Re: (dank24)
I've done plenty at work.
2 people are required of course.
1st pump 4 times and hold while other turns the bleed bolt and then tightens.
same for all 4.
Old Apr 1, 2007 | 07:33 AM
dank24's Avatar
****, I didnt tighten it every time after I bleed it. I had a tube going into a container with brake fluid so no air would get sucked back up. But no more air came out. I had a buddy pump it 5 times each.
Old Apr 1, 2007 | 11:04 AM
Rev4Ever's Avatar
how's your brakes now?
Old Apr 1, 2007 | 12:43 PM
oside jimc's Avatar
Doing that just sucks the bubbles back into the line.
Old Apr 1, 2007 | 03:00 PM
Rev4Ever's Avatar
Default Re: (oside jimc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oside jimc &raquo;</TD></TR><TR><TD CLASS="quote">Doing that just sucks the bubbles back into the line.</TD></TR></TABLE>
i worked at 3 dealerships and it works fine. The 2 Chevy dealers did that method. All though, BMW(my current dealership) has a tool that sucks it out by hooking it up to the bleed, but I doubt he has that tool.
Old Apr 2, 2007 | 08:43 AM
.Kevin.'s Avatar
Default Re: (Rev4Ever)
one man bleeder kit is your best friend 5$ well spent
Old Apr 2, 2007 | 12:58 PM
dank24's Avatar
so now i have pressure, but it seems like one of my brakes are rubbing
Old Apr 2, 2007 | 09:16 PM
Rev4Ever's Avatar
Which one?
.Kevin.'s Avatar
you probably did not push the pad far enough back into the calipar.
Old Apr 2, 2007 | 09:26 PM
Rev4Ever's Avatar
Default Re: (Ep_Kevin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ep_Kevin &raquo;</TD></TR><TR><TD CLASS="quote">you probably did not push the pad far enough back into the calipar. </TD></TR></TABLE>
Find which one is doing it and try EP_Kevin suggestion.
post back when u do
xaznxdrgnxboix
Jun 6, 2007 01:17 PM
StolenTeg
Sep 5, 2006 05:05 PM
detaude
Honda Motorcycles
May 18, 2005 03:46 PM
RTW DC2R
May 18, 2005 09:23 AM
B18Redline
Jun 23, 2002 09:48 AM
