Burned A Piston? What do you think?
Old Mar 31, 2007 | 04:43 PM
NOKTURNALCARCLUB's Avatar
Default Burned A Piston? What do you think?
We took my Hatch out to Skunk2 yesterday along with 2 other homies cars to Dyno and tune for Palmdale. Jerry and Dr. Charles were tuning my car when on the 3rd pass it hit 585WHP and i think a piston burned. It was tuned to 575 on 1000cc injectors at 24PSI. We upgraded to 1600cc injectors, changed to an AEM 5 Bar map sensor and turned the boost up to 35PSI. Not sure why it burned? Maybe i need a gas pump/sump set-up now? It also idles at 1k but jumps to 2k and drops back down to 1k back and forth and the exhaust is throwing white smoke. I missed palmdale, but now were going bigger bore 84mm and bigger pistons and im adding the pump/sump setup.... Hopefully with this it can handle the 35PSI and push over 650+
And thoughts on why it could have burned? too much boost on regular pump? My bore is 81.5mm, too small pistons?
Old Mar 31, 2007 | 05:48 PM
ke98248's Avatar
Default Re: Burned A Piston? What do you think? (SingleCamSI)
sounds like too much boost for your setup (ie too much HP)
civic-r11
Sep 19, 2011 09:24 AM
gsrwanted
Northeast (Sales)
14
Jan 17, 2009 02:06 PM
a1320honda
Sep 30, 2007 04:07 PM
fast[R]
Apr 17, 2002 02:50 PM
