><><> AiR CONDiTiON QUESTION!
Old Mar 31, 2007 | 03:09 PM
itsalmostfrieday's Avatar
Default ><><> AiR CONDiTiON QUESTION!
Is it really necessary to have the AC condenser fan on when the ac is on? My ac is in working condition but my fan isn't. I don't know if I should drive with my ac on if the fan isn't work. any suggestions, this is on my 99 civic ex if that makes a difference? Thanks
Old Mar 31, 2007 | 03:19 PM
eda6's Avatar
Default Re: ><><> AiR CONDiTiON QUESTION! (itsalmostfrieday)
the fan is there to reject heat.
w/o a cond. fan you'll trip the high pressure safety switch when the car is idling.
Old Mar 31, 2007 | 03:26 PM
Default Re: ><><> AiR CONDiTiON QUESTION! (eda6)
hmm, when my car is idling for like 10 mins without the condenser fan, my compressor starts to throb, like rockin back n forth. do you think its from the condenser flippin the high pressure switch that cause that to do that ? or is it just a bad compressor?
Old Mar 31, 2007 | 04:46 PM
Old Mar 31, 2007 | 04:55 PM
JDMFantasy2k's Avatar
the fan is pressure activated, when the high side pressure reaches something like 140psi, the fan will click on and i believe it will shut off around 115 PSI. Idiling has nothing to do with it, it's pressure activated, and if it doesn't come on then your system will reach a high pressure and the pressure switch will shut down the compressor.
Old Mar 31, 2007 | 05:13 PM
Default Re: ><><> AiR CONDiTiON QUESTION! (JDMFantasy2k)
ohhh, thanks a lot man!
Old Mar 31, 2007 | 06:58 PM
y7turbo's Avatar
great way to kill the compressor.
geribair
Jun 7, 2014 11:18 AM
si_motor_spt
Sep 29, 2012 09:00 PM
curioussavage
Honda Civic (2001 - 2005)
Jul 28, 2012 04:27 PM
emissionsux
Jul 7, 2005 09:43 AM
freddy_hung
11
Sep 21, 2003 07:32 AM
