Is it safe the run with the IAC valve sensor disconected?
Old May 25, 2002 | 06:27 PM
ITR1071's Avatar
Default Is it safe the run with the IAC valve sensor disconected?
My car idles at 3000 rpm all the time. I decided to unhook the IAC valve sensor and see what happens. It idles at 1500 rpm. I was wondering if this would cause a problem in the long run. I get a check engine light, but want to know some real consequences.
Old May 26, 2002 | 02:37 AM
tinkerbell's Avatar
Default Re: Is it safe the run with the IAC valve sensor disconected? (undercoverSI)
sounds like you have a SERIOUS vacuum leak someplace!
fix that and plug your IACV back in...
(no real consequnces if you dont though)
t..
Old May 26, 2002 | 11:37 AM
Chubz's Avatar
Default Re: Is it safe the run with the IAC valve sensor disconected? (tinkerbell)
no problems or performance loss, but when u unplug your IACV your idle should drop below 1000 rpms. Sounds Like you have a vacuum leak. Check your throttle body gasket and all vacuum lines going to the manifold. Also check the idle screw on the throttle body
Excusetoboost
Sep 1, 2011 07:40 PM
egturbo1
Jan 28, 2006 11:04 AM
Black93EG
10
Apr 27, 2004 10:39 AM
Projectg2i
Jan 12, 2003 01:21 PM
