nuts and bolts for turbo? help please..
I'm using a spoolin performance manifold. and a Garret T3 Sabb turbo. I went too home depot and I swear i tried them all and non were working. i know there is a differnce between coarse and fine thread, but none of them would easily go in. I don't get it, what is everyone else using? I think i determined that the nuts needed for the mani are a 3/8 hex. but the turbo exhaust side i have no idea, is that 5/16 bolt? any help is great . and I can post pics if need be.
Did you bring your turbo parts in with you inside Home Depot? That's what I did lol
Call Phil back at Spoolin and double check with him on the thread pitch, it should work. If worse comes to worse, you can always re-thread the manifold, in case there is a tiny booger somewhere that is making it difficult for you.
yah brought em in. i'll end up emailing phil. any idea on that turbo. in the pic i have a extra exhaust housing. Can those dowel type bolts be taken out and put into the current exhaust side.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flashmn »</TD></TR><TR><TD CLASS="quote">MAybe they're metric sized.</TD></TR></TABLE>
When I was getting all of the hardware together for my setup, I found that a couple things were not metric (which was kind of confusing at first haha).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shauniewalnuts »</TD></TR><TR><TD CLASS="quote">go to like an ace hardware or a small family owned hardware store and get some metric pieces, home depots bolt/nut selection sucks</TD></TR></TABLE>
True, I ended up getting the last of my hardware from Orchard Supply Hardware.
Yup, homedepot has a really shitty hardware selection.
There's a local ACE hardware that has absolutely everything, from automotive manifold studs, to O2 sensor plugs etc. They also have everything in stainless as well.
So yeah, definately try a smaller local hardware store, stear clear of homedepot for anything hardware related.
kamakaze1
Jul 18, 2006 12:16 PM
