b16 idle problem...idles @2500-3000 rpm
Old Mar 31, 2007 | 09:45 AM
cbabyby's Avatar
Default b16 idle problem...idles @2500-3000 rpm
i have a jdm b16 in a 93 civic ex...i just got done putting it back together.....started it up runs fine but it idles at 2500-3000 rpms.... throttle cable isnt even hooked up yet..... the adjuster nut isnt even turned down so low the car shouldnt even be running...... a buddy of mine told me to put some cardbord between the iacv and the intake......done that it dropped down to 2200 rpms..... i think my iacv is bad but its not throwing any codes other than IAT and that is because i got an hondata intake manifold gasket.....anyone please hlep....i need my car
Old Mar 31, 2007 | 09:52 AM
civicstar's Avatar
Default Re: b16 idle problem...idles @2500-3000 rpm (cbabyby)
try cleaning out IACV
Old Mar 31, 2007 | 11:30 AM
EG civic's Avatar
Default Re: b16 idle problem...idles @2500-3000 rpm (civicstar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicstar &raquo;</TD></TR><TR><TD CLASS="quote">try cleaning out IACV</TD></TR></TABLE>
x2
Old Mar 31, 2007 | 11:44 AM
cbabyby's Avatar
Default Re: b16 idle problem...idles @2500-3000 rpm (EG civic)
ok....with what....and if it doesnt fix the problem where can i find another one....new...for a jdm intake
Old Apr 1, 2007 | 05:25 PM
cbabyby's Avatar
bump......
Old Apr 1, 2007 | 05:44 PM
civicstar's Avatar
i forgot where but theres two types, one can be found on the integra ls (which has the longer bolt pattern, and then theres the one with the shorter bolt pattern found on the civic ex.
i cant remember if the b16 is a dual type, which can accept either, someone check me on this
Old Apr 5, 2007 | 11:07 AM
stuinbluesi's Avatar
check your TPS sensor for the right voltage
Old Apr 5, 2007 | 05:11 PM
integratee's Avatar
Default Re: b16 idle problem...idles @2500-3000 rpm (stuinbluesi)
I had the same problem when i did a B16 head swap on my GSR. Its the IAC sensor cable that is not hooked up into the right terminal (pretty sure). Clean it out by opening up the sensor and use intake manifold cleaner, its a spray. Get your helms out and check the harness cables depending on what harness you are running it to. Hopefully thats it. But I had the same symptoms...it bounced, it was high, and I fixed it by doing that, it was to the wrong sensor port. bleck/yellow. You also might need to adjust your throttle body by tightening the top screw (flathead) and adjusting the bottom screw (alan key and 8mmm i think) kepp us posted.
Old Apr 8, 2007 | 12:46 PM
cbabyby's Avatar
Default Re: b16 idle problem...idles @2500-3000 rpm (integratee)
well.....mine is the longer bolt pattern.....and i adjusted my idle enough.......so now it idles at about 1700....untill i can buy another iacv
Old Apr 9, 2007 | 08:35 PM
cbabyby's Avatar
Old Apr 10, 2007 | 08:31 AM
cbabyby's Avatar
i ordered a new iacv its supposed to be in thurs.... but this is the second time i swapped my motor i dont know why it would just mess up after i swapped it...... it ran fine when i took it out....
Old Apr 11, 2007 | 07:19 PM
cbabyby's Avatar
bleedblue94
13
Jan 4, 2006 10:05 AM
93civicjaydm
Jun 7, 2005 08:46 PM
B16CRXT
May 6, 2004 07:46 PM
91hatchcivic
May 24, 2003 07:07 AM
HaUTSaauce
Mar 30, 2003 04:12 PM
