REX Idles At 4K!
Old Mar 31, 2007 | 07:42 AM
haroldthefly91crx's Avatar
Default REX Idles At 4K!
i just put my si engine in an hf and i started it yesterday and as soon as it starts up the rpms shoot up to about 4000, i thought it was my tps so i unpluged it and started it and got the same thing
any ideas as to what my problem is?
Old Mar 31, 2007 | 09:00 AM
dephtone's Avatar
Does the idle kick down after it's warm?
Old Mar 31, 2007 | 10:18 AM
CRX_1.8T's Avatar
Default Re: REX Idles At 4K! (haroldthefly91crx)
check your vacuum lines... when mine did the same thing (idle at 4k) it was because a vacuum line on the back of my manifold had somehow fallen off.
Old Mar 31, 2007 | 02:09 PM
HF2ZC's Avatar
Did you check to see if the throttle cable is adjusted properly?
4cyl707
May 3, 2009 09:23 AM
DA9teg93
May 9, 2005 12:12 PM
Civichatch27
12
Oct 4, 2004 01:11 PM
.cingham
Apr 10, 2004 08:55 PM
89b16hf
Feb 17, 2004 07:31 PM
