itr ported intake manifold vs skunk 2 pro for jdmb18c
actually the topic title says it all...whould you prefer a ported intake from portflow for example or a skunk 2 pro one?the motor is a stock jdm b18c type r repprogrammed with aem cai, toda header and cat back 2 1/2 exchaust...
would you consider good value for money tha changing of the stock itr intake with one of the above intakes systems?which are the estimated whp gains?are we talking about 1-2 whp or sth much better like 4-5whp
is there any dyno charts availiable from people who changed their intake manifolds?
thank you!!!
thank you!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr1244 »</TD></TR><TR><TD CLASS="quote">why dont you get both of them and dyno test it and tell us what's better?
That or search...
http://www.importbuilders.com/...s.JPG
That or search...
Search in the All Motor or Drag Racing forum, there's SO many dyno test of EVERY part there. Espeically ported vs. aftermarket, that's a famous battle between whp numbers. Only people with sponsors or lots of money can actually do that kind of thing but the information is there. Hope this helps
Narrow your searches to one or two words and skim though the pages. ie, ITR manifold, ported, skunk2 manifold, intake manifold, dyno.
Here's some I found:
https://honda-tech.com/zerothread?id=1894327
https://honda-tech.com/zerothread?id=1871079
https://honda-tech.com/zerothread?id=1875959
Narrow your searches to one or two words and skim though the pages. ie, ITR manifold, ported, skunk2 manifold, intake manifold, dyno.Here's some I found:
itr1244: lol sorry but I cannot afford sth like that!!!though I am a fan of such actions!
racingangel:I have seen that dyno from import builders before,it is propably from a guy here in greece ho programmes honda ecus...it is from his car actually..but a second opinion is not sth bad!
spoon spec r: when I enter a forum I always try to search first but in honda tech I cant use the search function correctly for some reason....I searched and no resaults came up!!!mayby I used too many words!!!thank you!
Modified by MLoud at 3:08 AM 3/31/2007
no I do not think that getting a skunk 2 worths if you have an itr im but this is not my question..I asked if it is better to buy a PORTED itr im or a skunk 2 PRO im..
I know I'm probably missing something and I am probably being ignorant, but can we really expect that much out of a different intake manifold on a B18C5?
Aren't the intake manifolds pretty well tuned and matched in the first place?
Like the Spoon TB, I don't think I would tend to buy a new intake manifold for an ITR motor until I was in the last stages of tuning.
Maybe I don't know what I'm talking about, though/
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by George Knighton »</TD></TR><TR><TD CLASS="quote">I know I'm probably missing something and I am probably being ignorant, but can we really expect that much out of a different intake manifold on a B18C5?
Maybe I don't know what I'm talking about, though/</TD></TR></TABLE>
George - the stock ITR IM flows well but there is also a lot of improvement that can be done as seen below:
STOCK:
http://www.flickr.com/photos/47305622@N00/445069468/
IB CNC'd:
http://www.flickr.com/photos/47305622@N00/321914409/
If you've done mods like I/H/E, cams, internals etc - it's a very good upgrade to do.
STOCK:
IB CNC'd:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Big Phat R »</TD></TR><TR><TD CLASS="quote">
STOCK:
IB CNC'd:
If you've done mods like I/H/E, cams, internals etc - it's a very good upgrade to do.</TD></TR></TABLE>
IB doesn't do any main chamber work, and they also cut the TB flange in 1/2. My Endyn ported IM had both, an enlarged main chamber, larger runners, and no cut flange to worry about leaking (alignment).
STOCK:
IB CNC'd:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by confidance »</TD></TR><TR><TD CLASS="quote">has anyone sent there's off to be extrude honed? </TD></TR></TABLE>
I'm interested in this as well. I would love to see some pics/numbers.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by confidance »</TD></TR><TR><TD CLASS="quote">has anyone sent there's off to be extrude honed? the IB manifold numbers are nice but <u>it makes the manifold look horrible.</u> i like to keep things looking stock</TD></TR></TABLE>
You're kidding right? What are you some kind of sandbagger that races for pinks?
http://www.flickr.com/photos/47305622@N00/321914397/
http://www.flickr.com/photos/47305622@N00/321914398/
http://www.flickr.com/photos/47305622@N00/321914413/
Why are cosmetics such an issue?
Why are cosmetics such an issue?</TD></TR></TABLE>
i agreed the IB manifold looks mean as hell (even though it still the stock piece
). plus who gives a rats *** if you can see the welds if the gains justify the time and money spent. if you want a show car that looks pretty then sell your R. thats my .02
If looks were of concern, you can always grind down the weld and powdercoat the manifold. You wouldn't be able to see a seam.
As for the comparison, there are a few dyno charts floating around of the Import Builders IM versus stock ITR IM's on near stock/mild 1.8L motors. They do pick up a generous amount of midrange power, and the topend is improved a bit as well.
The original Skunk2 unit was very similar in design to the ITR IM, with the exception of a 65mm throat for accepting larger throttlebodies, along with a slightly larger plenum volume.
The Skunk2 Pro IM has longer runners, and a larger plenum volume compared to the original Skunk2 unit. Supposedly it makes 20% more power in some areas versus the old unit, but I havn't seen any data to back that up.
I would just go with the IB ported ITR IM or the Endyn ported ITR IM.
well i found out today its $495.00 to get your manifold extrude honed!!! its $5xx to have the port match on top of that.
guess getting it cut and ported is the best choice considering the cost
b19coupe
13
Oct 1, 2010 09:41 AM
SoyMilk
42
Sep 24, 2007 08:17 PM
92hatchattack
16
Jun 7, 2005 02:30 AM
