98 LS REVS at 5000RPM?>?? .....
ok here is the issue I would like to know if anyone has ran into this situation at all....ok when I rev the motor it revs up to 5000.......so I I checked everything on the car.... I swaped distributors, I swaped out tps sensor, I swaped out the map sensor, I swaped out ecu and spark wires...it doesn't bogg when I rev.. it doesn't pull no codes at all starts up fine idle is good as well. its a 98 LS motor in a 92 vx hatch...right now I'm leaning to start checking the fuel and checking if it will be a fuel issue instead of a sensor issue.........but I wouldn't think it would be a fuel issue cause if it was that issue.... would it end up boggin? all I remember from yesturday was when I was heading home of a sudden it start to choke real bad and act like it wanted to die....then of sudden it went back to normal....????? I'm lost...someone help meh...
RacinMasonC
May 28, 2008 09:21 PM
