DTC code 4, and 16 on DPFI
Old Mar 30, 2007 | 10:20 AM
h22Sicoupe's Avatar
Default DTC code 4, and 16 on DPFI
i have a 91 crx with DPFI, throwing codes 4(crank angle sensor) and code 16 (fuel injector). It won't rev past 3000 rpm.
check both circuits and components and everything is good. changed the ecu and distributor with a known good one and still the same problem. check timing, resistance of injectors and crank angle sensor and they're within specs. when i unplugg the secondary injector the engine idles fine and revs past 3000 rpm.
anyone experience this or can help me out? also during start up on DPFI engines should the secondary injector be on?
thanks
Old Mar 31, 2007 | 03:11 PM
h22Sicoupe's Avatar
Default Re: DTC code 4, and 16 on DPFI (h22Sicoupe)
anyone?
Old Mar 31, 2007 | 04:35 PM
blinger's Avatar
make sure wires in plugs are making contact with ECU. I was throwing a code 4 on my MPFI swap..turned out the plugs werent making good contact
Old Mar 31, 2007 | 05:47 PM
h22Sicoupe's Avatar
Default Re: DTC code 4, and 16 on DPFI (blinger)
thanks i'll look at that
Old Mar 31, 2007 | 08:08 PM
crxpwr1's Avatar
mines doing the same thing wont rev past 3 but mine is only throwing code 4...bump because I need to know to
red91hatch
Jun 6, 2008 06:23 AM
HONDABOND
Nov 9, 2003 12:59 AM
Herminator
Jun 28, 2003 03:45 AM
USDM 4G VTEC
Aug 31, 2002 05:00 PM
