how can i vtech my zc dohc???
i have a 91 civic hatch with a jdm zc dohc swap. i want to make it into a vtech but all i've heard is that only the sohc are vtech... how can i turn my stock zc dohc into vtech?
i don't have money for another swap. i was wondering is any of the b series vtech heads would work maybe? i dunno much about my zc its nice to have cuz everyone have the b series and i don't care if mines not fast as hell, at least it sticks out.
no a b series will not bolt up...unless you have a SOHC ZC you are out of luck...just swap it if vtec is so important to you...VTEc is highly over-rated...boost FTW
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redefsir »</TD></TR><TR><TD CLASS="quote">just put vtec stickers on it</TD></TR></TABLE>
wow your an idiot...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91hatchzc »</TD></TR><TR><TD CLASS="quote">i want to do autox</TD></TR></TABLE> what suspension do you have and you know if you have that motor it may put you in a different class...i suggest you upgrade all bushings, and maybe more...what is you suspenstion set up?
Wow, the quality of this forum keeps increasing
I agree with 89efDUSTY in that if you're planning to auto-x you should worry about suspension first. Then, depending on your class, you may be able to add a small turbo to the motor, it can handle low boost applications (I've even heard of up to 10 psi) on stock internals with a good tune.
.I agree with 89efDUSTY in that if you're planning to auto-x you should worry about suspension first. Then, depending on your class, you may be able to add a small turbo to the motor, it can handle low boost applications (I've even heard of up to 10 psi) on stock internals with a good tune.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wiZCo »</TD></TR><TR><TD CLASS="quote">Wow, the quality of this forum keeps increasing
I agree with 89efDUSTY in that if you're planning to auto-x you should worry about suspension first. Then, depending on your class, you may be able to add a small turbo to the motor, it can handle low boost applications (I've even heard of up to 10 psi) on stock internals with a good tune.</TD></TR></TABLE>
wizco sometimes we think alike its spooky
but then again its just common sense
.I agree with 89efDUSTY in that if you're planning to auto-x you should worry about suspension first. Then, depending on your class, you may be able to add a small turbo to the motor, it can handle low boost applications (I've even heard of up to 10 psi) on stock internals with a good tune.</TD></TR></TABLE>
if you are planning to autox (scca) i'd put the stock engine back in. hopefully you have an SI, and run STS
if you can't afford to swap to a better engine, they you aren't going to like what class you'll be in with that dohc ZC (Street Modified)
to be competitive in any way in that class you need R comp tires (about $140 each) very well setup suspension, and a tiny bit of power.
your best bet is Stock engine, suspension, and run in STS class. though that is a super tough class too!
how would you <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedSI90hatch »</TD></TR><TR><TD CLASS="quote"> give it vtec</TD></TR></TABLE> if your going to state something even if its stupid then you should back it with some tech, or else your as bad as people with Vtech in there Vocab. seriously damn people need to stop being idiots and help others...
Even if by help it means "use the search button stupid"
jdmjonny21
Nov 25, 2008 05:32 PM
