I Smell Something...
Old Mar 30, 2007 | 04:07 AM
Roxxy's Avatar
Default I Smell Something...
I have an 02 civic ex When I drive at high speed/distance more than 20 miles I smell something like plastic burning and yesterday it changed. Now smells like rubber burning and may be coming from the wheel area. Looked in the engine could see nothing but low brake fluid. Someone tell me I'm not crazy. Please?
Old Mar 30, 2007 | 07:21 AM
MR_FIX_IT's Avatar
Default Re: I Smell Something... (Roxxy)
how low r u...?
Old Mar 30, 2007 | 08:53 AM
Roxxy's Avatar
Default Re: I Smell Something... (Purple_GS-R)
everything is manufacture specs i haven't changed anything
Old Mar 30, 2007 | 09:27 AM
Relic1's Avatar
jack up the car and take a look at the underside of the car. also check out he wheel wells for the fender lining rubbing on the tire.
Old Mar 30, 2007 | 10:47 AM
Black4thgenEF's Avatar
Default Re: (Relic1)
At one point I had a wheel well liner come loose and at highway speeds the wind could push it against the tire -- you should check out the well liners.
Old Mar 30, 2007 | 02:41 PM
base-op.1320's Avatar
Default Re: (Black4thgenEF)
I had the same problem but it was my tires spinning hehe
Old Mar 31, 2007 | 09:17 PM
Darth_Accord90's Avatar
Do you have a standard tranny? Sometimes when it gets worn, or is out of adjustment, it can smell like rubber burning. But start off simple, do as the
other guy sasid, and check ur tires and wheel liner first. Good luck
Old Apr 1, 2007 | 11:04 AM
Crx Jimmy's Avatar
also check your belts
CivicSos
11
Aug 26, 2013 12:28 PM
vtec25
Mar 4, 2008 10:58 PM
Chris F
Mar 28, 2005 06:58 AM
grngsr01
May 8, 2003 01:53 PM
Rain_man
Jul 15, 2001 12:10 PM
