Wheel shake
Old May 1, 2003 | 09:13 PM
grngsr01's Avatar
Default Wheel shake
Anyone ever have a problem with toyo fz4's shaking and feeling like the car is extremely loose at higher speeds 65+. And yes the tires are balanced
Old May 1, 2003 | 09:33 PM
WiggiE's Avatar
New User
Default Re: Wheel shake (grngsr01)
Jack your car up. Grab the wheel and shake it side to side and up and down. If it has play side to side, it could be your tie rod ends. If it has play up and down, it could be your wheel bearings.
Old May 1, 2003 | 10:57 PM
ghettols's Avatar
Default Re: Wheel shake (WiggiE)
off topic, how exactly do you go about fixing the wheels bearings? i might have this problem...
Old May 6, 2003 | 10:20 PM
I Like Boost's Avatar
Default Re: Wheel shake (ghettols)
i am having a weird problem with wheel shake. the car feels normal under regular driving but when i start to rev it to like 4-5k rpm going over 40 or 50 mph the car shakes like the wheel is about to fall off! could it be the motor mounts?
Old May 6, 2003 | 10:22 PM
riceball777's Avatar
i have toyo fz4's and i have no problems with them at all
i think that its an great tire
Old May 7, 2003 | 08:20 PM
Deluzional's Avatar
Most of the time the wheel shakes because you need your tires balanced, but since yours is good, maybe you should check the thread pattern on the tire. My friend once almost got in an accident and had to slam on the brake while at the same time turning his tires to the side to stop which rubbed a lot against the thread causing the car wheels to shake while around 50-60 mph.
Old May 7, 2003 | 08:34 PM
Vinny Chase's Avatar
Default Re: Wheel shake (Deluzional)
Did you check to see if the tires were separating at all? Or just re-torque all your wheels again, you never know..
Old May 7, 2003 | 09:42 PM
jonoknut's Avatar
Default Re: Wheel shake (Vince10984)
chekc the lugs. if they are tight, take it back to where you got them put on and have them reblance them. i dont think it could be the tire, unless it was a defect or something but i think they check them out pretty well.
jon
Old May 8, 2003 | 01:09 AM
chinkiechunkie's Avatar
torq. the lugs to 85lbs.
Old May 8, 2003 | 11:09 AM
WiggiE's Avatar
New User
Default Re: Wheel shake (*****iechunkie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by *****iechunkie &raquo;</TD></TR><TR><TD CLASS="quote">torq. the lugs to 85lbs. </TD></TR></TABLE>
Correction: 80ft/lb
Old May 8, 2003 | 01:53 PM
Turbo Powa's Avatar
you people also forgot to mention that the rims may be bent...
valox138
Sep 29, 2008 09:11 AM
DAP97SI
12
Jun 4, 2007 01:51 PM
arren123
Jun 7, 2006 05:11 AM
Mish
Dec 23, 2002 10:11 PM
TurBoXBirD16
20
Jun 6, 2002 04:13 PM
