What to do if one tire pops?
Old Mar 30, 2007 | 01:41 AM
ThA IntegrA HI's Avatar
Default What to do if one tire pops?
So tonight me and my friend are driving through the backroads (not racing or even going fast) and I hit this part of the road where it just drops off about 6 inches (right from the line on the outside of the road). I guess I pulled it back onto the road and the road ripped the inside of my tire. The rest of my tires have a good amount of tread left on them but I don't think they sell the tires I have here. What should I do, replace just the one tire?
Old Mar 30, 2007 | 07:42 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: What to do if one tire pops? (ThA IntegrA HI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ThA IntegrA HI &raquo;</TD></TR><TR><TD CLASS="quote">I don't think they sell the tires I have here. What should I do, replace just the one tire?</TD></TR></TABLE>
The official answer you will hear from most folks is to use four matched tires at all times, so they will tell you to buy four new ones.
However, if you can buy one or two tires that are similar in performance to your old tires, you can get away with doing so. I think it's best to at least use the same tires on each axle (i.e. left front tire matches right front tire, left rear tire matches right rear tire). So if I were you, I would buy two new tires, keep the extra one you already had and rotate it in as needed.
Also discussed in this current topic.
What kind of tires have you been using? Make, model, size.
Old Mar 30, 2007 | 12:35 PM
hankook radial 106 195-50-15
Old Mar 30, 2007 | 01:19 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: (ThA IntegrA HI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ThA IntegrA HI &raquo;</TD></TR><TR><TD CLASS="quote">hankook radial 106 195-50-15</TD></TR></TABLE>
Those are still available. Just buy another one. Currently $41 at Edge Racing.
Old Mar 30, 2007 | 01:20 PM
KoketsuCivicSi's Avatar
replace the two tires
Old Mar 30, 2007 | 03:46 PM
old man neri's Avatar
Default Re: What to do if one tire pops? (nsxtasy)
Part of the answer also depends on how much tread is left on the existing tires. If they are fairly new you can get away with just replacing one or two. If the existing tires were almost due to be replaced you are probably better off getting 4 new tires, if you ask for advice as to what tires to get here you will probably get 4 much better tires suited to your needs.
Cheers.
Old Apr 2, 2007 | 12:35 AM
eMpAtHy's Avatar
Default Re: What to do if one tire pops? (old man neri)
the price of them is soo cheap compared to other tires, just go ahead and buy 2 new ones.
I would maybe think twice if they were say 200 dollars per tire.
VTECwalka
Mar 10, 2013 01:11 AM
G2_Fella
Sep 15, 2006 04:42 PM
ap1$2k
Honda S2000
32
Sep 9, 2006 05:26 PM
professorman
Honda Motorcycles
May 19, 2006 04:25 PM
wizzards581
35
Apr 27, 2004 06:29 PM
