LCA STUD STUCK!!!!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by migs »</TD></TR><TR><TD CLASS="quote">Air chisel the other side which is a welded nut to the LCA. All you would have to do is just either:
a) replace LCA
or
b) put a nut onto the end of the bolt next time you put one through.</TD></TR></TABLE> thats what i did on the other side.Put a nut on the other end instead of the welded nut.Im keeping my stock lca.Looking at air chisel right now
a) replace LCA
or
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by F1Spec »</TD></TR><TR><TD CLASS="quote">use a torch and heat it up </TD></TR></TABLE> torching will messed up my bushing so no can do.
Try using a jack to change the position of the lower control arm to relieve some pressure on the bolt itself. I've never had any problems getting one out with a breaker bar or impact gun.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by godnf8 »</TD></TR><TR><TD CLASS="quote">Try using a jack to change the position of the lower control arm to relieve some pressure on the bolt itself. I've never had any problems getting one out with a breaker bar or impact gun.</TD></TR></TABLE> The arm is off the car. Im glad everything goes easy for you
Ha ha, I have done that before.. I cut the strut out with a angle grinder (cutting between the stut and inside of the LCA. Its a grade 8 Bolt, your going to be hard pressed to drill it out of there, even with a big vice and drill press. This will likley damage the strut and it will have to be replaced. When you put it back together make sure you use a lot of copper lube to prevent this from ever happening again.
got it off the lca, but the stupid stud still stuck in the bushing!!! stupid bolt extractor **** dont even work!! boooo!! been drilling it all freakin day and probably the rest of the night!
Spence
14
Apr 25, 2004 10:22 AM
