ls/vtec install- need to adjust my throttle cable
Old Mar 29, 2007 | 06:54 PM
Tatakai's Avatar
Default ls/vtec install- need to adjust my throttle cable
so im finishing off my ls/vtec install (pray it fires up!!) and i'm going from the normal LS intake manifold to the GSR, and so the throttle cable bracket is a lot closer on the GSR. is there anyway i can get rid of the extra 3" of cable? motor is in an ej1 if that helps any.
thanks in advance
Old Mar 29, 2007 | 08:31 PM
tez_the_banana's Avatar
Pretty sure you need to adjust it from the pedal to properly shorten it.
Old Mar 29, 2007 | 09:14 PM
Tatakai's Avatar
Default Re: (tez_the_banana)
so there is a way to pull the cable back from the petal side? THANK YOU. i've asked this question on 3 forums and everyone just keeps telling me to "adjust the nuts" .......
Old Apr 1, 2007 | 06:14 PM
integ401's Avatar
did your car start? I'm doing a ls/vtec as well. Not even close to being done haha
Old Apr 1, 2007 | 07:58 PM
MI4$DC5's Avatar
Default Re: (integ401)
i would like to know also how to adjust the cable from the pedal
Old Apr 1, 2007 | 08:30 PM
mmuller's Avatar
Mad Scientist
Default Re: (MI4EH2)
you cant adjust that much
if you get creative you can put something behind the rubber cable stopper on the pedal to make up for the slack
Old Apr 2, 2007 | 10:27 AM
jlfrnce's Avatar
Default Re: (mmuller)
thats alot of slock there, i swapped in the whole b18c1 and had same issue so i ordered off eby a gsr throttle cable and direct fitment no modding it at all!
im_inn0c3nt
Jul 14, 2009 09:08 AM
lsvtecboi'95
Aug 4, 2007 07:53 PM
Touge Tuning
Apr 20, 2006 10:07 AM
2k2S4
Jan 11, 2004 12:16 PM
GSRacer
Oct 9, 2001 04:53 AM
