if your valves are moving out of specification what kind of symptoms occur?besides obvoious
Old Mar 29, 2007 | 12:21 PM
mattsnooz's Avatar
Default if your valves are moving out of specification what kind of symptoms occur?besides obvoious
I know you'll hear a ticking , and have poor fuel economy but what else would also tell you if your valves just need a little adjustment? (or rather if its something major)
My car sputters at idle with small misfires occasionally.
thanks for any help possible.
(p.s. did search on valves not too much showed up. srry still a newb gimmie a break ova here!)
Old Mar 29, 2007 | 04:09 PM
bluedlude's Avatar
Default Re: if your valves are moving out of specification what kind of symptoms occur?besides obvoious (mat
the sputtering you are hearing is a misfire most likely. check out your spark plugs to start.
Old Apr 7, 2007 | 06:39 PM
mattsnooz's Avatar
eh, had a valve adjustment, checked plugs, wires, cap, rotors good, still misfiring occasionally. alot less with adjustment
swapped95
19
Sep 30, 2007 06:29 PM
crxfreak88
Mar 10, 2005 07:26 AM
91 lude si
Sep 1, 2004 04:23 PM
Chuji
Sep 10, 2003 01:49 PM
