help with electronic vss install
Old Mar 28, 2007 | 07:48 PM
Braco11's Avatar
Default help with electronic vss install
car: 89 hf; obd0 b16, pr3 ecu
installing my jdm SiR cluster. re-wired everything up, got a b-series electronic vss, wired it up and my speedo doesn't work. checked the grounds and voltage, and it appears the vss is getting the appropriate voltage.
signal wire going to back of cluster (b1 on jdm cluster plug). that same wire gets spliced to the ecu, pin b16 (both yellow/red wires)
power wire goes straight to ecu, a15
grounded the ground wire
what else should i check? no speedo
Old Mar 28, 2007 | 09:38 PM
ThatRicerDaniel's Avatar
Default Re: help with electronic vss install (Braco11)
are you throwing any codes?
Old Mar 29, 2007 | 07:56 AM
Braco11's Avatar
Default Re: help with electronic vss install (ThatRicerDaniel)
nope
Old Mar 29, 2007 | 08:34 AM
Loserkidwac's Avatar
Hmm...are you sure the vss is good? Are you sure you used the corret wires off the plug?
Old Mar 29, 2007 | 08:58 AM
e jay one's Avatar
Default Re: help with electronic vss install (Loserkidwac)
black wire is ground middle wire on the plug is 12v and the other is signal. make sure you got a good plug. that happened on my old eg the spedo stoped working cause the plug was all coroded.
Old Mar 29, 2007 | 09:08 AM
Braco11's Avatar
Default Re: help with electronic vss install (e jay one)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by e jay one &raquo;</TD></TR><TR><TD CLASS="quote">black wire is ground middle wire on the plug is 12v and the other is signal. make sure you got a good plug. that happened on my old eg the spedo stoped working cause the plug was all coroded. </TD></TR></TABLE>
i'll have to go back and check to make sure i have the wires right. i'm pretty sure the middle was getting 12v though.
as for the vss, bought it off someone who said it was good.
Old Mar 29, 2007 | 09:14 AM
Braco11's Avatar
just checked. wires are right. plug looks fine. am i plugging them into the right slots on the ecu and cluster plugs? how can i tell if my vss is bad?
Old Mar 29, 2007 | 06:37 PM
How do you know you have a constant 12v? where are you pulling 12v from?
how did you verify ground is good?
Old Mar 29, 2007 | 08:53 PM
EF_LSVtec's Avatar
check your wiring again...
http://b16a.honda-perf.org/cluster.html
Old Mar 30, 2007 | 08:48 AM
Jonknee's Avatar
Default Re: help with electronic vss install (EF_LSVtec)
i have the same problem, im pretty sure its wired correctly, i get code 17, and sometimes the speedo will randomlly fluctuate from 0-10mph, its very rare for it to do that though, i get 12v middle wire plug, o on ground, and 4volts on signal wire, when i spin the tire on jackstands the signal wire fluctuates between 2 - 4 volts, im so lost here.
Old Mar 30, 2007 | 05:22 PM
Default Re: help with electronic vss install (Jonknee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jonknee &raquo;</TD></TR><TR><TD CLASS="quote">i have the same problem, im pretty sure its wired correctly, i get code 17, and sometimes the speedo will randomlly fluctuate from 0-10mph, its very rare for it to do that though, i get 12v middle wire plug, o on ground, and 4volts on signal wire, when i spin the tire on jackstands the signal wire fluctuates between 2 - 4 volts, im so lost here.</TD></TR></TABLE>
17 can spawn from alot of different things. all the way down to a missing screw on the back of the cluster. 17 is always a hard one to figure out.
Old Mar 31, 2007 | 05:51 PM
Jonknee's Avatar
omg lol now that i think about it, the same exact thing happened with my Temperature gauge and it turned out to be a loose screw behind the cluster, it would fluctuate alot, why didnt i think of this before, thanks daniel
teler86
May 24, 2006 09:32 PM
EF8IGHT
Feb 14, 2006 09:11 AM
2kTeg
Mar 30, 2005 04:56 AM
0 0 0
Dec 3, 2003 10:30 AM
jdmWONG
Dec 6, 2002 10:18 PM
