Is this clutch chatter?
Old Mar 28, 2007 | 04:47 PM
PreludePhill's Avatar
Default Is this clutch chatter?
When im at a light ill put it in grear and start to drive and ill hear a sound like there are rocks or somthing in the tranny.It will only do it at lower RPMs(1-4k).Like i said the clutch will be engaged and in gear when i hear this noise,any ideas?
Old Mar 28, 2007 | 05:01 PM
UNLTD's Avatar
Default Re: Is this clutch chatter? (PreludePhill)
no.
Old Mar 28, 2007 | 05:14 PM
InvaderTrax's Avatar
Clutch chatter is a very distinct vibration throughout the whole car when you first let the clutch out. You'll know when you experience it
Old Mar 28, 2007 | 06:02 PM
any idea on what it could be?Thanks for the replys
Old Mar 29, 2007 | 05:28 AM
sivikvtec's Avatar
Default Re: (PreludePhill)
when the car is sitting at idle do you hear the noise, but then it goes away once you push in the clutch?
Old Mar 29, 2007 | 05:58 AM
Mr.Luder's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PreludePhill &raquo;</TD></TR><TR><TD CLASS="quote">When im at a light ill put it in grear and start to drive and ill hear a sound like there are rocks or somthing in the tranny.It will only do it at lower RPMs(1-4k).Like i said the clutch will be engaged and in gear when i hear this noise,any ideas?</TD></TR></TABLE>no, u sure u have tranny fluid in ur tranny?
Old Mar 29, 2007 | 12:01 PM
Patman's Avatar
How do you fix clutch chatter, i think my stupid rx7 has it, the whole car like lurches, it sucks.
Old Mar 29, 2007 | 12:03 PM
jdmlude5
Guest
Posts: n/a
Default Re: (Patman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Patman &raquo;</TD></TR><TR><TD CLASS="quote">How do you fix clutch chatter, i think my stupid rx7 has it, the whole car like lurches, it sucks.</TD></TR></TABLE>
turn the flywhhel and while ur at it get a new clutch
Old Mar 29, 2007 | 02:26 PM
When im at idle there is no noise no matter what rpm i rev to.When im stopped whether i put it in first or im already in 1st gear and start to roll i hear the noise.Then ill shift to 2nd and ill hear it again for a little bit untill i get over 3500-4000 rpms
Old Mar 29, 2007 | 03:05 PM
98vtec's Avatar
moderator emeritus
wouldnt say that there is a way to "fix" clutch chatter other than being smarter in your choice of clutch.
Old Mar 29, 2007 | 05:29 PM
Well after jacking up the car and looking under the tranny i noticed that the small flywheel cover that came on my old USDM H22 was hitting the oil pan(JDM H22) causing a slight dent to be made in the pan and wearing on the flywheel cover.Also one of the bolts holding it on was also loose.So i took it off and im going to drive it tomorrow to see if thats the problem.
For a little more background info.Last year i did the JDM H22 swap and i belive the JDM motor was a 4th gen motor because the oil pan is entirerly different then my old USDM h22,thus causing the flywheel cover to not fit correctly.
skata89
May 19, 2007 09:01 PM
kihun_cha
Mar 22, 2007 05:16 PM
futurefastguy
Oct 13, 2006 10:32 AM
816d16
14
Nov 16, 2005 08:26 AM
hitvtecgetloud09
Aug 6, 2005 08:55 PM
