Front H&R Race springs way too low?
Old Mar 28, 2007 | 02:29 PM
GraphiteMW's Avatar
Default Front H&R Race springs way too low?
Holy ****, I just installed my front h&r race springs and my stock 15's are tucking tire!! Its about a finger width tire tuck.. is this normal? I am running aftermarket tires so maybe its just the high side walls? The rear's had a reasonable drop to what I expected but holy crap the front!!
Old Mar 28, 2007 | 02:31 PM
BrockNB's Avatar
Default Re: Front H&R Race springs way too low? (GraphiteMW)
I dont see the problem.
Your lookin low. Its pimpin.
Old Mar 28, 2007 | 02:32 PM
GraphiteMW's Avatar
Default Re: Front H&R Race springs way too low? (BrockNB)
I mean the tire tuck isn't anything too bad but the rear's didn't even up the look, it dropped but it dropped as much as the front then I wouldnt care.
Old Mar 28, 2007 | 03:35 PM
93h22a1vtec's Avatar
h&r race, stock front struts, kyb rear struts. 205 45 16 for the front tires, rear are 215 40 16
Old Mar 28, 2007 | 03:47 PM
MooJenLude's Avatar
I think it might be your rim/tire setup either that or the springs are worn...or maybe your struts are worn...You've got some camber issues
Old Mar 28, 2007 | 04:52 PM
GraphiteMW's Avatar
Default Re: Front H&R Race springs way too low? (Snuggles.FTW)
Springs don't get worn that bad to where is loses it drop zone by that much.
Modified by GraphiteMW at 9:16 PM 3/29/2007
Modified by GraphiteMW at 6:15 PM 3/30/2007
Old Mar 30, 2007 | 02:16 PM
GraphiteMW's Avatar
Bump!!
I just now remembered when we pulled my struts out they had no bump stops at the time i didn't know what they looked like but we pulled some struts out of a friends EF and he had some.. Could that be why I got that extra drop in the front?
Old Mar 30, 2007 | 02:28 PM
h22aBB4's Avatar
shouldn't be- that just affects it when your strut is all the way compressed
Old Mar 30, 2007 | 02:35 PM
GraphiteMW's Avatar
Default Re: (h22aBB4)
Then any idea why my front end is slammed and tucking tire so bad? I'm thinking my struts/shocks are blown.. I read up on symptoms of blown shocks and it says unlevel car and sags lower then the rear. I have all those problems.
Old Mar 30, 2007 | 06:27 PM
Apex1972's Avatar
are you sure you got the right springs on the front of the car??? I know it sounds crazy, I bought my 92 Si from a guy in FL and it had AGXs and Ground Controls. After taking my suspension apart numerous times and not being able to get the car to sit level, I found out the springs will interchange front to rear. Maybe that is what happened???
Old Mar 30, 2007 | 07:22 PM
GraphiteMW's Avatar
Default Re: Front H&R Race springs way too low? (Apex1972)
The springs that were label F were short and the R springs were a pretty long.. I'm sure I got it right though?
Old Mar 30, 2007 | 08:48 PM
Apex1972's Avatar
just wondering, because I recently removed my Ground Controls for Skunk 2 drop springs and they had no markings at all to tell front from rear. Maybe better shocks would help.
Old Mar 31, 2007 | 01:55 AM
ninja 6's Avatar
did you just install it or has it settled?
if you're running a huge tire, like a 205-60-15, it is def possible after it settles.
Old Mar 31, 2007 | 07:44 AM
GraphiteMW's Avatar
Default Re: Front H&R Race springs way too low? (Shiny Toy Gun)
These were bought used so I am guessing they were alread settled in pretty nicely.
Old Mar 31, 2007 | 09:14 AM
92_prelude's Avatar
My car is tucking tire too. I installed some eibach springs and kyb shocks. I didn't know what a bumpstop looked like until I read about it on a thread. It could be that because my springs shouldn't even lower the car more than 1". Its at 2 1/2" right now!
honda_student
23
Dec 24, 2008 10:13 PM
Ramocheese
Jul 26, 2004 06:30 PM
pdiggitydogg
49
May 15, 2004 06:15 PM
JFG Kevin
Jan 14, 2004 12:57 AM
ebelp
Apr 17, 2002 03:37 PM
