00 SI Engine Harness for Ls/Vtec(NEED HELP!!)
Old Mar 28, 2007 | 01:22 PM
ekbobby's Avatar
Default 00 SI Engine Harness for Ls/Vtec(NEED HELP!!)
hey everybody i just got my 00 si harness back from this guy arnel and he did an AWESOME job! Now i am looking through my si manual and labeling all of the sensors according to their wire colors. So far i have labeled these--->
Vtec solenoid
Lock-Up Control Solenoid Valve
Engine Coolant Temperature Sensor
IAT Sensor
MAP Sensor
Crankshaft Positioning Sensor
Throttle Positioning Sensor
IACV
Evaporative Emission Purge Solenoid Valve
All Injectors
Alright i need help labeling these--->
I have 2 sensors that have a GREEN WIRE and a BLACK WIRE.
1 sensor that has 2 wires,a BLUE W/BLACK STRIPE wire and a BLACK wire(located by the vtec solenoid)
1 sensor that has 1 wire- RED/BLUE STRIPE
1 sensor that has 1 wire- YELLOW/RED STRIPE
1 sensor that has 2 wires- WHITE/RED STRIPE and BLUE/RED STRIPE
The sensors that i HAVE NOT labeled i could not find in my manual and i looked for like 3 hours...?
Old Mar 29, 2007 | 06:55 AM
ekbobby's Avatar
Default Re: 00 SI Engine Harness for Ls/Vtec(NEED HELP!!) (ekbobby)
ttt any suggestions?!!
Old Mar 31, 2007 | 07:37 AM
ekbobby's Avatar
I need some help!!
Old Mar 31, 2007 | 06:05 PM
redtegger03's Avatar
Default Re: (ekbobby)
Not sure of the colors but when you start to bolt the harness onto the motor...the plugs usually fall into place pretty close to where they are supposed to go...
some sensors u didnt mention...
VSS, located on top of the transmission...3 wire
reverse light indicator, 2 wire
vtec pressure sensor,
Oil pressure sensor, (has the round shaped grommet at the end usually) on the back of the block to the left of the oil filter..
all i can think of without looking at it right now, hope that helps
neroren
Feb 27, 2010 11:28 AM
HamiltonRex
May 23, 2008 03:20 PM
stephen_civic98
Audio / Security / Video
Mar 19, 2007 02:37 PM
dxhatch93
Mar 25, 2006 02:22 PM
theonly3rd
Nov 10, 2004 04:30 PM
