did i wire the prox. sensor correctly?
Old Mar 16, 2006 | 05:06 PM
dxhatch93's Avatar
Default did i wire the prox. sensor correctly?
I connected the 508d proximity sensor to my Viper 791xv. The problem im having is that if i set off the proximity sensor, it shows sensor 1. If i set of the shock sensor, it also shows sensor 1. How can i get the alarm to differentiate between sensor 1 and sensor 2? I connected the red to red, black to black, and the blue and green from the prox. i connected both of them to the blue. The loose green wire from the harness, i connected that as well to the blue wire. The green wire that loops, i left untouched. If i did any of the wiring wrong, can you please point it out? thanks.
Old Mar 16, 2006 | 06:16 PM
B18C_EJ8's Avatar
Since you tapped into the shock sensor input, it's only going to show sensor 1 as triggered, regardless of which unit activates.
Are you using any of the other inputs? Like the trunk or hood trigger? If not, hook the prox sensor up to one of those... If all triggers are hooked up, then you'll have to live with the problem...
Old Mar 16, 2006 | 08:21 PM
dxhatch93's Avatar
Default Re: (B18C_EJ8)
yea all my other triggers are used. while looking through the manual i noticed that theres a sensor 1 and sensor 2?
Old Mar 16, 2006 | 09:39 PM
EGPrelude's Avatar
Default Re: (dxhatch93)
you can hook it up this way
This would show up as your "2" sensor being triggered for the proxy
Old Mar 17, 2006 | 07:00 AM
rrei's Avatar
Default Re: (EGPrelude)
doesnt that alarm have a seperate port for optional sensors, so you dont have to tap in
Old Mar 17, 2006 | 07:27 AM
B18C_EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">doesnt that alarm have a seperate port for optional sensors, so you dont have to tap in
No. Has just the shock sensor plug, and separate triggers for hood, trunk and door.
Old Mar 17, 2006 | 10:26 AM
fcm's Avatar
fcm
Old Fart
You have it wired incorrectly, Zone 1 and 2 are not the same as sensor 1 and 2, if you have the manual go to page 33, [shock sensor harness 4-pin connector] or go here and scroll down to 32... http://www.directeddealers.com...5.pdf 94
Old Mar 17, 2006 | 12:00 PM
dxhatch93's Avatar
Default Re: (fcm)
thanks egprelude and fcm, i wired it the way yall pointed out and it shows as 2 different sensors!
Old Mar 25, 2006 | 02:22 PM
FULL throTTLe's Avatar
man that is confusing
bopbop93030
Audio / Security / Video
Aug 14, 2009 06:15 AM
Dub C
Aug 7, 2008 05:20 AM
stephen_civic98
Mar 19, 2007 02:37 PM
icedaccord19
Feb 6, 2004 08:28 AM
rex03
Dec 30, 2003 03:41 PM
