Honda S2000 Honda S2000
s2000 window wont roll up ?????
Old Mar 28, 2007 | 10:24 AM
98or00gsr's Avatar
Default s2000 window wont roll up ?????
ok so i sold my vafc2 to my friend that has an ap1 s2000 (i think ap1, dont no if that matters anyways) but like i said i sold him my vafc2 and he hooked it up correctly and all the wires are clean up. but now that the vafc2 is hooked up, his passenger window will not roll up. however everything else in the car (ex. drivers window, lights, locks) all work perfectly fine.. does anyone have any sort of ideas on what may of happend.. i believe that it may of been a freak accident that the passeger window motor went out at the same time as the install... any ideas ???? tahnks
Old Mar 28, 2007 | 11:48 AM
NathanielH's Avatar
Default Re: s2000 window wont roll up ????? (98or00gsr)
im not sure where you mounted it, or how the wiring is run on an s2000, but you either messed (spliced into, or accidently cut) a wire that leads to the window motor or switch, or it is completley unrelated and just a fluke. Get a test light, make sure the switch is providing pwr to the motor, and check for pwr at the motor itself.
Old Mar 28, 2007 | 12:51 PM
dkim48's Avatar
Default Re: s2000 window wont roll up ????? (NathanielH)
did you check the window lock switch on the driver's door panel? check that first before ripping it all apart
Old Mar 28, 2007 | 01:02 PM
LAS2K's Avatar
Default Re: s2000 window wont roll up ????? (dkim48)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dkim48 &raquo;</TD></TR><TR><TD CLASS="quote">did you check the window lock switch on the driver's door panel? check that first before ripping it all apart </TD></TR></TABLE>
x2 i think we've all done this before.
Old Mar 28, 2007 | 01:07 PM
WowOzYouRock's Avatar
Default Re: s2000 window wont roll up ????? (LAS2K)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LAS2K &raquo;</TD></TR><TR><TD CLASS="quote">
x2 i think we've all done this before. </TD></TR></TABLE>
or maybe just you... ROFL
Old Mar 28, 2007 | 01:44 PM
LAS2K's Avatar
Default Re: s2000 window wont roll up ????? (FR-MOB: Jerk)
/cries
Old Mar 28, 2007 | 09:01 PM
Techno Tonis's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98or00gsr &raquo;</TD></TR><TR><TD CLASS="quote">ok so i sold my vafc2 to my friend that has an ap1 s2000 (i think ap1, dont no if that matters anyways) but like i said i sold him my vafc2 and he hooked it up correctly and all the wires are clean up. but now that the vafc2 is hooked up, his passenger window will not roll up. however everything else in the car (ex. drivers window, lights, locks) all work perfectly fine.. does anyone have any sort of ideas on what may of happend.. i believe that it may of been a freak accident that the passeger window motor went out at the same time as the install... any ideas ???? tahnks</TD></TR></TABLE>
no way in hell does a window motor just die for no reason, so you can rule freak coincidence out.
i would definetly suggest that you have the child lock on for the window. that seems like it would make the most sense, because if you ended up splicing any wires for the passenger door...which doesnt make any sense to begin with..you wouldnt have everything else working so perfectly, imo it doesnt make any sence. can someone pull up diagrams of the window motor and its connecting wires to help him out? i cant find any, and i am extremely lazy.
also, you need to be more specific...does it roll down but not up? is there no response at all? can you here the motor trying to turn?
Old Mar 29, 2007 | 06:00 AM
NathanielH's Avatar
Default Re: s2000 window wont roll up ????? (Techno Tonis)
window motors can go out out of no where. Trust me, i deal with 10-15 window motor claims per day, as a claims adjuster for an extended warranty. Really this guy just needs to perform a basic circut check. (check fuse, make sure switch is reciving power, check for power out of the switch, check for power at the window motor, check for ground at the window motor, ect...)
Old Mar 29, 2007 | 08:22 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NathanielH &raquo;</TD></TR><TR><TD CLASS="quote">window motors can go out out of no where. Trust me, i deal with 10-15 window motor claims per day, as a claims adjuster for an extended warranty. Really this guy just needs to perform a basic circut check. (check fuse, make sure switch is reciving power, check for power out of the switch, check for power at the window motor, check for ground at the window motor, ect...)</TD></TR></TABLE>
i stand corrected then.
Old Mar 29, 2007 | 10:15 AM
98or00gsr's Avatar
so it was definitly just the window lock buton.. very funny.. thanks for the help
02EX
Jun 1, 2015 04:25 PM
i_VTEC
Honda S2000
12
Oct 18, 2011 06:58 AM
gliaZeD
Aug 19, 2011 11:15 AM
staticrex
Sep 19, 2005 11:30 AM
Edgemingsr
Jun 2, 2004 10:08 PM
