why is there a grease on the alternator plug?
Old May 25, 2002 | 06:28 AM
The_In_Kid's Avatar
Default why is there a grease on the alternator plug?
ok my alternator has been bitching around and working then not working then working all because of a plug...
i bent the connectors on the plug to make it tighter fitting then i took a tooth brush and cleaned off all the grease...
but why is there grease inside of it? whats it for? it seemed like the major cause of my alternator problem... after i cleaned it up the alternator is running like new and i never get that battery light again....
Old May 25, 2002 | 09:23 AM
smokin rubber's Avatar
Default Re: why is there a grease on the alternator plug? (The_In_Kid)
the grease helps keep water off the connection.
Old May 25, 2002 | 06:05 PM
ricksaccord's Avatar
The other guy is right about grease does repel water, It also keeps it from corrrodeing. If you look at a new or rebuilt (alt) you will see a little dab of dielectric
grease on the plugs.
Fireman Jim
Dec 30, 2012 10:38 PM
steve052386
Jun 4, 2007 11:22 AM
98prelude98
Jun 2, 2005 09:12 AM
_jester_
Dec 13, 2003 08:00 AM
