how much should i advance my timing.
Old May 25, 2002 | 05:21 AM
Audi A4's Avatar
Default how much should i advance my timing.
i have a drag 3 setup, adn boosting 4 pds. wah should i advance my time too?
Old May 25, 2002 | 06:41 AM
IN VTEC's Avatar
Default Re: how much should i advance my timing. (DRAG lll INTEGRA)
Generally, you shouldn't and can't if you've got a turbo. In most cases, you have to retard to timing to prevent detonation from grenading the engine. If you guys never retarded the ignition timing when you first put the turbo on the car, then it's probably still sitting somewhere b/w 14 to 16 degrees BTDC.
Hit up the FI forum and ask what kind of ignition timing values they use with their Drag III LS's. I can suggest asking DIRep972, he's also got a Drag-powered LS.
Go get a timing light and find out what it's at now before you regret the rest of your life.
Old May 25, 2002 | 07:50 AM
Audi A4's Avatar
Default Re: how much should i advance my timing. (IN VTEC)
ok thanks alot.
Old May 25, 2002 | 08:19 AM
EagleR's Avatar
Double check in the FI forum but i think with only 5 psi, retard it like 2-4 deg.
Old May 25, 2002 | 09:49 AM
GSR901's Avatar
Default Re: how much should i advance my timing. (EagleR)
i think that you should never go over 18 degrees anyway.
Old May 25, 2002 | 11:05 AM
SIK IN DA HED's Avatar
New User
Default Re: how much should i advance my timing. (B18Cwon)
advance timing on a turbo b18? are you crazy!
some people leave it at stock timing boosting only 5lbs. i retarded mine 1 degree. keep your timing retarded to 14-15 degrees just to be on the safe side. make sure youre running colder plugs too. bcpr7es11 NGK
mortificationrock
Jul 10, 2007 04:26 PM
vtekstorm
Mar 13, 2004 10:18 AM
gsrguy
Feb 7, 2004 02:10 PM
wrXtian
Mar 25, 2003 03:55 PM
