Can I use this vacuum port?
Old Mar 28, 2007 | 06:07 AM
ILcrxsi1's Avatar
I tell doctors what to do
Default Can I use this vacuum port?
The pcv port with the white vacuum cap on it. Can I use it for my boost guage or something? I'd rather not just have it capped off.
Old Mar 28, 2007 | 06:24 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: Can I use this vacuum port? (ILcrxsi1)
it is a source of manifold. use it. are you running a vent system or a catch can? why arent you using the pcv system?
Old Mar 28, 2007 | 06:29 AM
ILcrxsi1's Avatar
Default Re: Can I use this vacuum port? (boostedcivicsir)
I don't know what you mean by vent system. Do you just mean catch cans without a vacuum source? If so yes. Here https://honda-tech.com/zerothread?id=1917722
Old Mar 28, 2007 | 06:33 AM
Mr. Badwrench
just have the 2 hoses coming off of the block into tha tanks? there is no where for the pressure to go. this is just my oppinion from the pics, if i saw it in person i could make a better judgement.
but to answer your question, you can use the port as a source of manifold vacuum.
Old Mar 28, 2007 | 07:19 AM
ILcrxsi1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir &raquo;</TD></TR><TR><TD CLASS="quote">just have the 2 hoses coming off of the block into tha tanks? there is no where for the pressure to go. this is just my oppinion from the pics, if i saw it in person i could make a better judgement.
but to answer your question, you can use the port as a source of manifold vacuum.</TD></TR></TABLE>Somebody else in that thread said the same thing about the pressure. I guess I just take bad pics because there is plenty of room to breath. One hone comes from the block the other come from the valve cover breather.
Thanks for answering the question though .
2000__GSR
Jul 21, 2010 06:52 AM
josh0407
May 5, 2007 08:12 PM
Bradstard
Jul 19, 2006 05:40 PM
blackeg
Jul 14, 2006 07:22 AM
BB6racer
Dec 7, 2005 07:07 PM
