sliding swaybar???
Old Mar 27, 2007 | 08:20 PM
leomodz's Avatar
Default sliding swaybar???
i have a 00 civic coupe. rear suspension setup: SRR LCA, Tokiko illumina coil overs, polyurethane bushings, ASR brace, Skunk works 22mm sway w/ greaseable sway bar D links & stock SI end links.
Question... Installed the asr brace & sway bar a few days ago, and for some reason it looks like the swaybar has shifted to the driverside.. Looks like almost hitting the shock assembly.. leaving a 2" space on the other side. Has anyone ever seen anything like this before? Is the swaybar supposed to slide side to side?
Old Mar 27, 2007 | 08:23 PM
Eran's Avatar
HT White Ops
Did you retorque everything with the wheels compressed or at full droop?
If you didn't compress the wheels to normal ride height and rock everything around (especially the endlinks, they like to bind), then your swaybar probably has some wicked preload.
Old Mar 27, 2007 | 08:26 PM
BlueIntegraBoy's Avatar
Default Re: sliding swaybar??? (leomodz)
The sway bar shouldn't shift over unless the endlinks are bent, or the bolts aren't tight, which might cause it to shift.
Old Mar 27, 2007 | 08:28 PM
leomodz's Avatar
Default Re: (Eran)
Good suggestion... Ill try that. thanks man... I just have to figure out how im gonna get under there when the car is down... prob use some bricks... thx again...
Old Mar 27, 2007 | 08:29 PM
Eran's Avatar
HT White Ops
Default Re: (leomodz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by leomodz &raquo;</TD></TR><TR><TD CLASS="quote">Good suggestion... Ill try that. thanks man... I just have to figure out how im gonna get under there when the car is down... prob use some bricks... thx again...</TD></TR></TABLE>
Yep, jack your car up REAL high, slide a cinderblock under each rear wheel, and go to work.
K20egcw
Suspension & Brakes
14
Sep 5, 2012 07:59 PM
zippo1130
15
Jan 15, 2008 07:45 PM
thegreat0ne
Aug 24, 2007 09:29 PM
CWBETB
Apr 9, 2007 10:30 AM
MaaseyRacer
Aug 17, 2004 09:40 PM
