sliding swaybar???
sliding swaybar???
i have a 00 civic coupe. rear suspension setup: SRR LCA, Tokiko illumina coil overs, polyurethane bushings, ASR brace, Skunk works 22mm sway w/ greaseable sway bar D links & stock SI end links.
Question... Installed the asr brace & sway bar a few days ago, and for some reason it looks like the swaybar has shifted to the driverside.. Looks like almost hitting the shock assembly.. leaving a 2" space on the other side. Has anyone ever seen anything like this before? Is the swaybar supposed to slide side to side?
HT White Ops
Did you retorque everything with the wheels compressed or at full droop?
If you didn't compress the wheels to normal ride height and rock everything around (especially the endlinks, they like to bind), then your swaybar probably has some wicked preload.
Re: (Eran)
Good suggestion... Ill try that. thanks man... I just have to figure out how im gonna get under there when the car is down... prob use some bricks... thx again...
HT White Ops
Re: (leomodz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by leomodz »</TD></TR><TR><TD CLASS="quote">Good suggestion... Ill try that. thanks man... I just have to figure out how im gonna get under there when the car is down... prob use some bricks... thx again...</TD></TR></TABLE>
Yep, jack your car up REAL high, slide a cinderblock under each rear wheel, and go to work.
CWBETB
04-09-2007 10:30 AM
