92 civic d15b oil problem
Old Mar 27, 2007 | 07:46 PM
jordansmcdonald's Avatar
Default 92 civic d15b oil problem
my motor burns alot of oil, ive checked the timing, done compression test , everything seemed ok i dont know were to go from here, someone told me the piston rings, but do i have to do the sleeves as well? any info would be greatly appreciated
Old Mar 27, 2007 | 07:58 PM
94hondacivicvtec's Avatar
Default Re: 92 civic d15b oil problem (jordansmcdonald)
do a leakdown test, if you dont know what that is or how to do it heres a link
http://www.c-speedracing.com/h...n.php
Old Mar 28, 2007 | 02:38 PM
Default Re: 92 civic d15b oil problem (94hondacivicvtec)
that link does not work
Old Mar 28, 2007 | 04:11 PM
philliman69's Avatar
leak down tests aint a joke, to do one correctly you need the tester and the knowhow to do it correctly. the test is not that expensive $100-$120 cheaper if you know someone. the way your talking it sounds like rings, but the test will tell for sure. (cheating way to do it is get a spark pluck hole air hose hookup, shoot your cylinders. if any shoot air to the oil pan its rings.)
Old Mar 28, 2007 | 11:36 PM
BAMF_SOHC's Avatar
Default Re: 92 civic d15b oil problem (philliman69)
Could be valve seals, I know my buddies B18A1 was doing the same thing and we replaced the valve seals...and sha-bam no oil leak...but yeah leak-down good investment...just to see.
PreClude
Jul 8, 2011 03:20 PM
jdmdc2110
Jan 28, 2006 10:48 PM
Old_Honda
Apr 5, 2005 08:25 PM
Blaze45
Jun 27, 2004 09:20 PM
Accel Junky
Apr 28, 2003 02:18 PM
