Power Door Locks Keep Clicking
Old Mar 27, 2007 | 06:12 PM
building boost's Avatar
Default Power Door Locks Keep Clicking
I have a really weird problem. If i push the button to unlock all the doors, the locks will make a crazy clicking noise and unlock like 5 times on the passenger side. What could it be? Does it have anything to do with my passenger side window going up and down really slow? Thanks.
Old Mar 27, 2007 | 06:13 PM
totsie7944's Avatar
Default Re: Power Door Locks Keep Clicking (building boost)
sounds like it might be a wire loose somewhere...but I doubt it has anything to do with your window man.
Old Mar 27, 2007 | 08:04 PM
Splat's Avatar
Collector-o-Guns and Drinker
Default Re: Power Door Locks Keep Clicking (totsie7944)
Window is a typical Integra problem. Fix should be on here somewhere.
Your door lock issue is most likely a bad wire like totsie said, or a failing relay. I'd put money on the wire.
Old Mar 27, 2007 | 08:11 PM
andrew dc's Avatar
Have you taken off the door panel for any reason? if so, the door handle has a plastic "hook" that needs to be tucked in behind the metal bracket. If you just screwed it in without tucking it, you are letting the door panel press against the lock rods. I just did this this weekend.
Old Mar 27, 2007 | 09:15 PM
yea i took out the panel to put new speakers in. i will check on that tomorrow. thanks for the help guys.
dc2long
Jun 1, 2011 02:53 PM
ken00si
May 12, 2009 04:47 PM
GSRCRXsi
Dec 1, 2004 03:30 PM
danslee
Jun 30, 2004 03:42 PM
Vinny Chase
Audio / Security / Video
Jun 22, 2003 05:06 PM
