Vacuum system hose sizes?
Old Mar 27, 2007 | 05:01 PM
busyychild's Avatar
Default Vacuum system hose sizes?
I want to replace all of the hoses in the vacuum system as most of them are old and brittle. I wanted to know if anyone knew off hand what the sizes were for the hoses with the exception of the stock air intake hoses. From what I can recall the majority of the hoses are the same diameter, only a few are different.
I think they are a mix of 4, 6, and 10 mm.
Thanks in advance!
Modified by busyychild at 7:51 PM 3/27/2007
Old Mar 27, 2007 | 07:18 PM
SteveoBA8's Avatar
Default Re: Vacuum system hose sizes? (busyychild)
I think there is a number on the lines 7-8mm iirc.
Old Mar 27, 2007 | 09:17 PM
Hawkze_2.3's Avatar
Vacuum hose is very cheap. Just go to the auto parts store and get several feet of all the small diameter hoses.
Old Apr 15, 2007 | 07:23 PM
Flip.'s Avatar
Default Re: Vacuum system hose sizes? (Hawkze_2.3)
Bringin this one back real quick.
How high does the quality have to be for vac hose. I bought some hose the other day but it feels really weak(kinda soft) to the point I can squeese it and block the hose. Just wondering if theres gonna be any problem with this, I'm thinking that under load I might have some problems.
Anyone have any input?
Old Apr 15, 2007 | 07:53 PM
Hawkze_2.3's Avatar
Default Re: Vacuum system hose sizes? (Flip01)
If it's made for use a vacuum hose it will be fine. It may not last as long as silicone hose (for example), but it should work.
Old Apr 15, 2007 | 08:06 PM
Flip.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_2.3 &raquo;</TD></TR><TR><TD CLASS="quote">If it's made for use a vacuum hose it will be fine. It may not last as long as silicone hose (for example), but it should work.</TD></TR></TABLE>
It is vacuum hose but I'm just not sure how good the quility has to be to be able to hold up under load. I haven't had any problems so far but I think I might just buy something a bit better just to be safe.
Any idea where to buy good quality hose online?
Old Apr 15, 2007 | 08:20 PM
Hawkze_2.3's Avatar
I HIGHLY reccomend http://www.hosetechniques.com. Probably not the cheapest, but they have great service and very good quality hose. I've been buying stuff from them for years...
You can a universal silicone hose assortment for $60
Old Apr 15, 2007 | 08:54 PM
Flip.'s Avatar
Thansk for that. I'll take a look now
HndaOwner
Mar 8, 2016 04:14 PM
greasemonkee
Welding / Fabrication
13
Jun 21, 2008 11:10 PM
YoungKadafi
Apr 3, 2007 12:31 PM
hose
Honda Motorcycles
Jun 19, 2006 08:28 AM
rac3rb0i
Aug 22, 2004 10:06 AM
