Cleaning EF
Old Mar 27, 2007 | 03:44 PM
GarretCRX's Avatar
Default Cleaning EF
all right I came up on this chasis 91 EF. It has no carpet but it does have this black layer, almost like f**k if I know tar or some crap. Anywho its pretty stuck to the floor what the best way i can remove it? I tried scraping it only works in certain spots and other spots is are really stuck. I even tried heat gun but that will take forever . thanks in advance.
Old Mar 27, 2007 | 04:41 PM
C1CRX's Avatar
Traffic signal tech
go buy some dry ice at a store break it into small pieces lay across the areas where the sound deadening material(tar) is and wait a few minutes for it to dry it up and use a hammer and chisel to remove makes it much easier.
Old Mar 28, 2007 | 07:23 AM
mrbh22's Avatar
Default Re: (C1CRX)
or get a good adhiesive remover and a scotchbrite pad and be paitent. there is no fast way to do this but you have to be paitent. it willl end sometime
Old Mar 28, 2007 | 12:37 PM
DA-nteg's Avatar
Default Re: ()
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by C1CRX &raquo;</TD></TR><TR><TD CLASS="quote">go buy some dry ice at a store break it into small pieces lay across the areas where the sound deadening material(tar) is and wait a few minutes for it to dry it up and use a hammer and chisel to remove makes it much easier.</TD></TR></TABLE>
yes indeed... makes it really easy. i bought a block of it, and broke it into big peices, waited 10 min, chiselled right off, moved ice to next location waited... a very effective way indeed
Old Mar 28, 2007 | 02:15 PM
GarretCRX's Avatar
Thanks I will try it this friday.
Old Mar 30, 2007 | 06:09 PM
GarretCRX's Avatar
Default Thanks C1CRX
Thanks for helping me out C1CRX the dry ice idea worked out perfect. It removed that tar crap very good.
THIS WAS TODAY
Old Mar 30, 2007 | 06:11 PM
C1CRX's Avatar
Traffic signal tech
Default Re: Thanks C1CRX (GarretCRX)
no prob man.
Old Mar 30, 2007 | 10:58 PM
computerfreak's Avatar
Default Re: Thanks C1CRX (C1CRX)
Nice tip, very nice to know something like that haha
ef_ben
Mar 22, 2008 12:08 PM
olskoolhatchy
Dec 9, 2007 04:49 PM
JcDrMx
Jul 24, 2007 09:34 AM
blk90sihatch
25
Jul 17, 2006 07:48 PM
