Ground control Install problems *searched*
Im trying to install my ground control coil over kit with the stock struts. Im running into a problem when putting the top hat over the strut, and it bearly seeds on there. attached is a picture
As you can see the top hat does not go over the spring completely..
what exactly am I doing wrong on the install here? Im still working on the front, and only a couple hours of daylight left. Please help.
it looks like the metal dust boot is jammed bet. the top hat and the silicone piece . the dust boot shld go in first and that silicone pc. needs to sit in the top hat
okay, well i took the back ones off, and they were just like this actually.. there was a gap in the spring.. im guessing because since its such shorter of a spring, it just cant contact. Im betting it'd be allright once I just put it back in with it all intact now that I think about it. because the way that picture was taken that was for a 3 1/2" drop from the stock.. so that'd make sence, maybe im not as dumb as i thought.
chi@1001
Jul 10, 2001 08:53 AM
