does it make sense to do an alignment?
yea i'm pretty low, and was thinking would it make sense to do an alignment. i have a camber kit but being that low can only have so much camber. but help me out here.
would it fix my tire wear. hopefully i'll wear it out evenly?would my tires last theirnormal life, cause i change tires every three months.
it wont "even out" whats already uneven.
but an alignment is necessary to ensure your tires wear evenly from the start.
you wasted your money getting a camber kit and not even an alignment. you just needed an alignment to correct your toe.
true but is the toe adjustable? the camber kit came with the car. i can see your point though. thanks for the reply's, i'll get the alignment done.
