96 ls vtech in 99 ek ?
Old Mar 27, 2007 | 02:32 PM
blade0314's Avatar
Default 96 ls vtech in 99 ek ?
hey i was just wondering if a 96 ls VTECH block and a 2000 b16 head and a p28 chipped computer would fit in my 1999 honda civic ex and if not what modifications are needed ? thanks
Modified by blade0314 at 4:09 PM 3/27/2007
Old Mar 27, 2007 | 02:34 PM
91EF_Si's Avatar
Default Re: 96 ls vtech in 99 ek ? (blade0314)
SEARCH!!!
Old Mar 27, 2007 | 02:37 PM
Eran's Avatar
HT White Ops
Yes, it will fit.
Yes, you will need different mounts.
No, it's not spelled "VTEC" .... it's VTEC (Variable Valve Timing and Electronic Lift Control)
Yes, you will need to modify the wiring harness.
It's apparent you don't know the first thing about Hondas, so just pay a shop to do it.
Old Mar 27, 2007 | 03:12 PM
ARMED's Avatar
engine mounts...
exhaust....
wiring harness..some people said, you can actually work on what you have...
obd2-1 harness so you can use your p28
shift linkage...
Old Mar 27, 2007 | 03:24 PM
2mansi's Avatar
Ok dude it will fit but u will need some things to make it work
1. 99-00 si mounts.....on the driver side u will need to change the mount that's attached to the block from a 3 to 2 metal piece.
2. Make sure you alternator, wiring harness, and distributor are all obd2......for the wiring harness you need to make sure its obd2b (99-00 si harness). You can use your ex one if need be.
3. Axles from a 94-01 5 speed integra or a 99-00 si....you can also use the ones from the b series del sol
4. Some sort of b series hydro transmission
For the most part that should be it. You will also need a b series half shalf (spelling).
Old Mar 28, 2007 | 04:59 PM
blade0314's Avatar
Default Re: 96 ls vtech in 99 ek ? (2mansi)
hey thanks for all the info but what excatly do u mean by "on the driver side u will need to change the mount that's attached to the block from a 3 to 2 metal piece" ? and what does a b series half shalf (spelling) mean
Old Mar 28, 2007 | 05:34 PM
doood's Avatar
been there done that
Default Re: (Eran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran &raquo;</TD></TR><TR><TD CLASS="quote">
It's apparent you don't know the first thing about Hondas, so just pay a shop to do it.</TD></TR></TABLE>
best advice yet
mish__
Apr 7, 2012 07:09 PM
jksmith
Jan 19, 2009 05:25 PM
nix94delsol
Jun 13, 2007 02:41 PM
blade0313
Mar 28, 2007 06:43 AM
prototype2
Sep 8, 2005 07:48 PM
