50 or 57 trim
Old Mar 27, 2007 | 12:29 PM
anton_'s Avatar
Default 50 or 57 trim
the setup is b16a1 with itr cams
2,5 carge piping equal lengd manifold
3" downpipe
reving 8700
and planing to boost 17psi, now i am boosting 14 with a to4b 48trim
what is best the 50 or 57. i made a calulating and i think the 50 trim is better when you look at these pictures.
a 50 trim also should spool faster.
iam using it as a daily driven car. but i want plenty of horse power to. around 380 whp
dot one is 4500 rpm 8 psi of boost
dot 2 is 5500 and 17psi boost
dot 3 is 6600 17 psi of boost
dot 4 is 8500 17 psi of boost
and i put a picture of the t04b to. it is not a effective turbo
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Old Mar 27, 2007 | 12:47 PM
spoolin turbo s's Avatar
Default Re: 50 or 57 trim (anton_)
i would go with a 50 trim compressor and a .63 turbine or if you really don't care about lag bump it up to a .82 hotside
the 50 trim is more efficient
i like it it a poor man's gt3071r
Old Mar 27, 2007 | 12:57 PM
Puscifer's Avatar
Default Re: 50 or 57 trim (spoolin turbo s)
380hp - 50trim w/ .63a/r hotside
Old Mar 27, 2007 | 12:59 PM
Default Re: 50 or 57 trim (Puscifer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Puscifer &raquo;</TD></TR><TR><TD CLASS="quote">
380hp - 50trim w/ .63a/r hotside </TD></TR></TABLE>
Motor Specs?
Old Mar 27, 2007 | 01:01 PM
boostincoupe's Avatar
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
What motor and how much boost?
Old Mar 27, 2007 | 01:59 PM
Puscifer's Avatar
I suggested 50trim w/ .63a/r for 380whp
It would be real responsive for street driving.
Old Mar 27, 2007 | 02:01 PM
Fo-Do Fanatic's Avatar
GT4042R... Teehhh Heeee!!!
Old Mar 27, 2007 | 02:28 PM
blinx9900's Avatar
Default Re: 50 or 57 trim (b00sted-Hatch)
57 trim imo, it dosent really effect spool but it will give you more room for max power later on.
Old Mar 27, 2007 | 02:51 PM
PA MATT's Avatar
Default Re: 50 or 57 trim (blinx9900)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blinx9900 &raquo;</TD></TR><TR><TD CLASS="quote">57 trim imo, it dosent really effect spool but it will give you more room for max power later on.</TD></TR></TABLE>
I agree, the spool time will be neglible between the two...probably around 300 rpm's difference(not much when your boosting and r's are moving fast). 57 trim leaves room to grow and will be better IMO. 50 trim will still do the job, but definetly don't go with a .48 a/r though, .63 a/r is going to be much better. I know it's a d16, but here's what I think is a good read comparing the two:
http://www.turbod16.com/viewtopic.php?t=31040
Old Mar 27, 2007 | 02:58 PM
blinx9900's Avatar
Default Re: 50 or 57 trim (PA MATT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PA MATT &raquo;</TD></TR><TR><TD CLASS="quote"> I know it's a d16, but here's what I think is a good read comparing the two:
http://www.turbod16.com/viewtopic.php?t=31040</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by anton_ &raquo;</TD></TR><TR><TD CLASS="quote">the setup is b16a1 with itr cams
3" downpipe
reving 8700
Old Mar 27, 2007 | 03:20 PM
PA MATT's Avatar
Wow, you got me there....
It's still a comparison of the two turbo's on 1.6 liters.....and thought it might help
Old Mar 27, 2007 | 03:40 PM
turb0teg's Avatar
My 50 trim on the B18a hits full boost around 3000rpms.
Old Mar 28, 2007 | 12:30 AM
anton_'s Avatar
Default Re: 50 or 57 trim (turb0teg)
yes it will be a 63 ar on the turbine and a stage 3.
Old Mar 28, 2007 | 07:32 PM
anton_'s Avatar
bump
Old Mar 28, 2007 | 10:24 PM
AbitAvenger's Avatar
id go 50 trim
ohsnapzafingcu
May 22, 2013 07:49 PM
flangemastermike
Feb 7, 2007 05:30 PM
1990hondaHF
Aug 5, 2003 11:54 AM
SimonsTeg
Sep 13, 2002 01:38 AM
