overheat!!!
Old Mar 26, 2007 | 07:57 PM
GiceMob's Avatar
Default overheat!!!
i got a problem with my car,when it warms up the temp is fine but then after a little while the needle go's up like 3/4 of the gauge but then it goes down to normal,what could i do to fix it.....
Old Mar 26, 2007 | 08:03 PM
ke98248's Avatar
Default Re: overheat!!! (GiceMob)
Your thermostat may be a little wacky, maybe you want to try and replace it? Its only like $15-20 bucks.
Old Mar 26, 2007 | 08:43 PM
GiceMob's Avatar
Default Re: overheat!!! (ke98248)
thanx,that's what my bro told me but just wanted to make sure what u guys thought it was!thanx
Old Mar 26, 2007 | 09:06 PM
Del_solution's Avatar
try checking the coolant level first, then check the thermostat , if that doesnt fix it check the fan, if that doesnt fix it check for the dreaded head gasket.
jmacc8
Honda Civic (2001 - 2005)
Aug 20, 2010 11:52 AM
lisajasmin
11
May 25, 2008 10:42 PM
SlammedDC2
Dec 3, 2006 07:47 PM
meanTheDope
Aug 22, 2005 10:31 AM
Nocturnal
Feb 22, 2004 08:48 AM
