fuel pump size
Old Mar 26, 2007 | 06:03 PM
Syndacate's Avatar
Default fuel pump size
What's the fuel pump size on a '95 EX coupe? Not sure if I wanna get an OEM or an aftermarket.
Any particular brand(s) that people have had exp w/ besides walbro?
My fuel system's shot to **** (keeps throwing 43 CEL), need a FPR or a fuel pump as I'm putting out insufficient fuel pressure (37 @ idle and 43 @ WOT as helms calls for 40-47).
I'm thinking of putting a 255lph fuel pump in w/ an adj FPR and letting it dump at 47 to stock specs so my fuel system (with the exception of the fuel rail and injectors) is basically ready for me to build.
Any input is thanks.
EDIT:
PS: I changed both fuel filters already (the fuel filter on the firewall and the fuel filter inside the gas tank (attached to the end of the fuel pump)) and still no change in PSI, so I'm thinking the FPR is crapping out as with electric fuel pumps they usually just die . Thinking of just killing 2 birds w/ one stone, upgrading while replacing the fuel system, and hopefully prepping it for swap and possible boost.
Old Mar 26, 2007 | 06:57 PM
SkoundrelUSA's Avatar
cute little bastard
Default Re: fuel pump size (Syndacate)
255 is overkill.
Just run a 190. It supports up to 350hp anyway and like $10 cheaper than 255
Old Mar 26, 2007 | 07:53 PM
Syndacate's Avatar
Default Re: fuel pump size (SkoundrelUSA)
10 dollars cheaper, eh?
190? What's the OEM one?
Old Mar 26, 2007 | 08:34 PM
cute little bastard
I bought mine off someone here for $75 shipped
OEM IIRC is 145
Old Mar 31, 2007 | 06:14 AM
Syndacate's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkoundrelUSA &raquo;</TD></TR><TR><TD CLASS="quote">I bought mine off someone here for $75 shipped
OEM IIRC is 145</TD></TR></TABLE>
Sounds good, thank you very much.
5honda
Sep 28, 2018 10:17 PM
sasinorm01
Mar 19, 2015 09:28 AM
hondaapi
May 13, 2010 04:40 PM
sway892
Jun 4, 2004 04:46 PM
