d15b vs zc
Old Mar 26, 2007 | 11:20 AM
ludecrasy87's Avatar
Default d15b vs zc
ok i wanted to know like whats the difference between the jdm d15b and the zc engine?
Like i want to do a swap into my hatch and i notice both engines are cheap but just one has vtec, but both have the same power dont they?
Also as for gettin ur replacements like water pumps and so for the zc youll get them for the integra 88 right?
And for the d15b u be gettin them for the d16 or is it another one?
Old Mar 26, 2007 | 11:21 AM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: d15b vs zc (ludecrasy87)
what zc there are a few of them you need to state what ZC you were looking at if you are not a sure a link could help.
Old Mar 26, 2007 | 11:41 AM
Default Re: d15b vs zc (Ace$nyper)
http://www.hmotorsonline.com/s...30022
Old Mar 26, 2007 | 12:07 PM
Ass$nyper's Avatar
Ah ok that is the dohc zc.
one happens to be a dohc one happens to be a sohc..
use some of the FAQs about the dohc zc, not a bad lil motor at all.
Old Mar 27, 2007 | 08:06 AM
ya i was told that the zc is great to boost.
Now i was wonderin for parts for this engine i will be getting it for the integra 86-89 usdm right?
Now for camshafts how do i go by gettin them? Like i will like to upgrade the internal when im boostin.
Also like for headers or the turbo manifold i seen zc boosted already but where would you be gettin the manifold from?
Old Mar 27, 2007 | 10:36 AM
wiZCo's Avatar
Stouts 'n' Scotch
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludecrasy87 &raquo;</TD></TR><TR><TD CLASS="quote">ya i was told that the zc is great to boost.
Also like for headers or the turbo manifold i seen zc boosted already but where would you be gettin the manifold from?</TD></TR></TABLE>
Don't be confused about the DOHC ZC. It's *similar* to the 1st gen Integra D16A1 but also shares a lot of parts with the D16A6 out of the Civic/CRXs.
Here's a parts list for you: http://www.thezcr.com/forums/s...12262
In fact, if you're serious about bulding, check that website out and sign up. Also, check out http://www.zcspeed.com, it's run by jlicrx on here, he really knows his stuff when it comes to that motor.
Old Mar 27, 2007 | 12:40 PM
EmOne Status's Avatar
yea almost all parts are interchangalbe with 1st gen integra motors except for timing belt you have to use the 88 prelude
Old Mar 28, 2007 | 12:19 PM
Default Re: d15b vs zc (EmOne Status)
ok but i really want to know wats the advantage of the engines compare one another?
I know ones SOHC and other DOHC but one has Vtec other doesn't. But they both pull the same HP 130?
Is it that you can mod one engine more than the other or is it just mainly wat it looks underneath the hood?
Old Mar 28, 2007 | 02:50 PM
janz3n's Avatar
dohc zc has less aftermarket support then the sohc.
svacca1
Sep 15, 2007 06:52 PM
turnsignalandy
Apr 17, 2006 10:46 PM
RACEPAK
May 18, 2005 11:03 PM
LorenGeist
24
Aug 18, 2004 05:43 AM
