Fusible link
Old Mar 26, 2007 | 07:34 AM
Booz's Avatar
Default Fusible link
When changing out my system from my 90 crx to my 89 I had to take apart the fusible link in my battery wire and I lost the glass fuse that went in the link. Here's a picture: the metal circle connects to + battery terminal and the battery wire from the amp goes in the end, and the very end of this link in unscrewable where a fuse goes in.
http://www.partsamerica.com/pr...3062A
My question is, what type of fuse do I put back in there? I know it's glass but I don't know the amperage. Can I use it w/o a fuse? I do right now but I'm not sure if that's gonna give me problems. I've been to the auto stores and no one seems to know exactly what goes in it.
Old Mar 26, 2007 | 01:24 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: Fusible link (Booz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Booz &raquo;</TD></TR><TR><TD CLASS="quote">When changing out my system from my 90 crx to my 89 I had to take apart the fusible link in my battery wire and I lost the glass fuse that went in the link. Here's a picture: the metal circle connects to + battery terminal and the battery wire from the amp goes in the end, and the very end of this link in unscrewable where a fuse goes in.
My question is, what type of fuse do I put back in there? I know it's glass but I don't know the amperage. Can I use it w/o a fuse? I do right now but I'm not sure if that's gonna give me problems. I've been to the auto stores and no one seems to know exactly what goes in it.</TD></TR></TABLE>
First I never seen a honda with a fusible link. Is that fuse holder powering your soundsystem?
Old Mar 26, 2007 | 02:29 PM
B18C_EJ8's Avatar
Second that... My '88 Escort had fusible links (why my dash lights didn't work) but I haven't seen a Honda with one that I can remember...
I bet you're talking about one of these:
As far as the fuse that goes in there, that's completely dependent on your amp...
Old Mar 27, 2007 | 12:53 PM
Booz's Avatar
Default Re: Fusible link (wrx-killer-Sti eater)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wrx-killer-Sti eater &raquo;</TD></TR><TR><TD CLASS="quote">
First I never seen a honda with a fusible link. Is that fuse holder powering your soundsystem?</TD></TR></TABLE>
Yes it is, the fusible link is used exclusivley for the battery wire running to my amp. And the fuse is more like a safety precaution, but my main purpose is that w/o the fuse the connectors don't touch and my system cuts off until I can push them back together. But when I had a fuse in there it never happened. As of now I have them taped together w/ electrical tape but I liked the fuse better.
Old Mar 27, 2007 | 12:56 PM
B18C_EJ8's Avatar
Then it's not called a fusible link. It's called a fuse holder.
Regardless of what it's called, as stated above by me: <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">As far as the fuse that goes in there, that's completely dependent on your amp... </TD></TR></TABLE>.
Old Mar 27, 2007 | 01:02 PM
Booz's Avatar
Default Re: (B18C_EJ8)
Indeed, the 'end' of the fusible link is the fuse holder (it would seem obvious) but the fuse holder is on the end of a fusible link
Old Mar 27, 2007 | 01:53 PM
imadigitalgod's Avatar
Default Re: (Booz)
how big of system is that fuse powering?<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Booz &raquo;</TD></TR><TR><TD CLASS="quote">And the fuse is more like a safety precaution
yes that is exactly what it is for.if i am understanding this correctly, you are pushing the 2 ends of the fuse holder without a fuse inbetween....if this is true do not push the 2 ends together without a fuse in hte middle! do you realize that your wire will melt if the wire has a short? a fuse protects the wire from that happening, thats why everything has a fuse.
if you have any size of a system, get a fuse holder like shown above with the gold ends. from what I see, the fuse link or whatever u want to call it, is way too small.
Old Mar 27, 2007 | 02:13 PM
B18C_EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Indeed, the 'end' of the fusible link is the fuse holder (it would seem obvious) but the fuse holder is on the end of a fusible link </TD></TR></TABLE>
No, you're mistaken. Please see definition of "fusible link" below.
http://www.google.com/search?h...title
Now that you've turned this into a total pissing match because you're misusing terminology, you have a fuse and a fuse holder.
So again, I ask you, how much current is your amp drawing? That will dictate the value of the fuse that you will put into the fuse holder.
Old Mar 27, 2007 | 02:22 PM
Booz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">
Copied from the link above for the lazy...
# That part of a fuse which is designed to melt when the rated current is exceeded.
[url=http://www.e-ratecentral.com/resources/help/glossary/f.asp]http://www.e-ratecentral.com/r...f.asp</TD></TR></TABLE>
# Soft, heat sensitive metal latch that holds a faucet or safety funnel open. In the event of a fire, the link melts, allowing the faucet or funnel to snap shut.
http://www.bascousa.com/tools/glossary.aspx
# Designed to perform the same task as a fuse, but resembles a wire. Fusible links are commonly used in ignition switches and other high current circuits.
http://www.sfxaudio.com/AudioSchool/glossary.asp
# Wire designed to open a circuit by melting, when too much current flows through it..
http://www.autobodyexpert.com/...s.htm[/quote][/quote]
[/QUOTE]
K.
If you don't have a solution this topic isn't for you.
Besides, refer to the original post and see that the part 'I' have from where 'I' bought it from that is the name. If that part was called a crayon I would refer to it as crayon.
Edit:
Lol, you def. just edited that post b/c it rambled on.
But really, I'm the OP and did not make this topic "LET'S ARGUE OVER WHAT YOU CALL SOMETHING". Swallow your pride and walk away, this is my last post for you.
Old Mar 27, 2007 | 02:35 PM
B18C_EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">If you don't have a solution this topic isn't for you.</TD></TR></TABLE>
I guess you haven't read my 3 responses where I gave you the solution... The parts where I said:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">As far as the fuse that goes in there, that's completely dependent on your amp...</TD></TR></TABLE>
and
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">how much current is your amp drawing? That will dictate the value of the fuse that you will put into the fuse holder. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">But really, I'm the OP and did not make this topic "LET'S ARGUE OVER WHAT YOU CALL SOMETHING". Swallow your pride and walk away, this is my last post for you. </TD></TR></TABLE>
You, not me, created a thread title that is unrelated to what you're asking for...
Old Mar 27, 2007 | 02:39 PM
nsxxtreme's Avatar
If you can get to the fuse then you do not have a fuseable link. You have a fuse holder.
Old Mar 27, 2007 | 03:08 PM
suspendedHatch's Avatar
Default Re: (nsxxtreme)
Wow, this is retarded. Just go to Circuit City or Best Buy and buy a goddamn fuse. 60A. You'll be fine. If your fuse holder doesn't accept the kind of fuses they carry, then just buy a goddamned fuse holder.
You sure take that "safety precaution" very lightly.
Stop being a dick to the people that are trying to help you out.
Old Mar 27, 2007 | 04:05 PM
ARMED's Avatar
what kinda power are we talkin about here...
is it a small amp???
100 is aight...
if you wanna use one...
i dont use fuse anymore for my system
Old Mar 27, 2007 | 04:16 PM
B18C_EJ8's Avatar
Default Re: (ARMED)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ARMED &raquo;</TD></TR><TR><TD CLASS="quote">what kinda power are we talkin about here...
100 is aight...
i dont use fuse anymore for my system</TD></TR></TABLE>
Unless you're using a circuit breaker, I'll be waiting for the "My car caught on fire" thread...
Old Mar 27, 2007 | 04:44 PM
This is a fusable link
http://www.alanhorvath.com/54c...s.php
Once blown it has to be replaced. The whole dam thing is no good. I not sure who told you it was something else. Go to any cc or bb or any stereo shop and tell them that you need a fusable link. There going to look at you real funny and tell you the same thing that we are preaching to you here. Face it. Its not what you think it is.
problems been solved and explained
3x lock
3x lock
Old Mar 27, 2007 | 06:02 PM
Booz's Avatar
Default Re: (suspendedHatch)
100 is aight...
Thank you.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by suspendedHatch &raquo;</TD></TR><TR><TD CLASS="quote">Wow, this is retarded. Just go to Circuit City or Best Buy and buy a goddamn fuse. 60A. You'll be fine. If your fuse holder doesn't accept the kind of fuses they carry, then just buy a goddamned fuse holder.
Stop being a dick to the people that are trying to help you out.</TD></TR></TABLE>
I'd say thanks to you, but I like being a dick to those who help me out.
Old Mar 27, 2007 | 06:11 PM
Booz's Avatar
Default Re: (wrx-killer-Sti eater)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wrx-killer-Sti eater &raquo;</TD></TR><TR><TD CLASS="quote">This is a fusable link
3x lock
3x lock</TD></TR></TABLE>
Isn't that the same thing as what I first posted?
Old Mar 27, 2007 | 06:27 PM
B18C_EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">I'd say thanks to you, but I like being a dick to those who help me out.</TD></TR></TABLE>
And we'll remember that...
Old Mar 27, 2007 | 06:59 PM
EBP_SI's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">As far as the fuse that goes in there, that's completely dependent on your amp... </TD></TR></TABLE>
Its actually dependent on the wire size you're using, not the amp
Old Mar 27, 2007 | 07:01 PM
EBP_SI's Avatar
Unless you're using a circuit breaker, I'll be waiting for the "My car caught on fire" thread... </TD></TR></TABLE>
and if you are using a circuit breaker i'll be waiting for the "My car caught on fire" thread
Old Mar 27, 2007 | 07:56 PM
Default Re: (ARMED)
i really hope this is some joke that you think its alright to not use a fuse on a system. if its just for your car, alright, let it burn down, but i hope u never touch other ppls cars and tell them its ok tonot use a fuse.
why wouldnt you use a fuse in the first place? They are cheap as hell and saves ur car if there is a short .
if answers to that is "well it keeps blowing", well if it keeps blowing, theres a problem with the amp or the actual wire itself(or too small of fuse for the wire).
Old Mar 27, 2007 | 11:02 PM
ARMED's Avatar
Default Re: (imadigitalgod)
its not a joke...
and i know im not the only one that does this...hehehehe
and no...ive had my car for years, with no fuse(s)...its ok..
b18c_ej8...you might see a thread about whatever you talkin about...and i bet you its not gonna be my thread....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EBP_SI &raquo;</TD></TR><TR><TD CLASS="quote">Its actually dependent on the wire size you're using, not the amp </TD></TR></TABLE>it depends on the amp how big, your cables and fuses gonna be.....
you cant just use a 12 guage cable on a 8000 watt amp can you...
12 guage is soo small..thats like a speaker wire....(for an 8K watt amp)
thats why it depends on the amp
if...if...you did..how many amps of fuse you gonna use??? on a 8K watt amp with a 12 guage cable????
Modified by ARMED at 12:50 AM 3/28/2007
Modified by ARMED at 12:51 AM 3/28/2007
Old Mar 28, 2007 | 02:53 AM
Default Re: (ARMED)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ARMED &raquo;</TD></TR><TR><TD CLASS="quote">its not a joke...
No, its really NOT ok. What if you DO have a short? Your car would be f**ked, but be my guest.
Seriously why would you not use a fuse? Its what, maybe a few bucks? This is exactly the type of thinking that makes manufacturers make people like me(that actually know how to install things RIGHT) pay people at shops to install stuff for me.
My house hasn't burnt down b4, does this mean I should cancel my home insurance?
Not using a fuse that costs a few bucks because your car hast burned down yet is one of the most stupid ignorant thing I have heard.
Old Mar 28, 2007 | 03:22 AM
EBP_SI's Avatar
Default Re: (ARMED)
Modified by ARMED at 12:51 AM 3/28/2007</TD></TR></TABLE>
Don't try and lecture me about fusing when you know nothing about it.
you're missing the whole point of what i said. chosing your wire depends on which amp you're going to be running. Then you fuse the wiring according to what guage it is. saying your fusing depends on your amp is an incorrect statement and can lead to unsafe installations (like yours).
Old Mar 28, 2007 | 04:59 AM
Booz's Avatar
Default Re: (EBP_SI)
This thread is starting to go downhill. I just need to know what amperage glass fuse I need to put in my fuseholder that is part of my fusible link.
I found my amp, unfortunately it is one for sale so no specs are really listed:
http://cincinnati.craigslist.o....html
It sucks, but it gets the job done.
Don't know the gauge of my battery wire but I will check as soon as I get to my car.
