which cams with stock B16a?
Old Mar 26, 2007 | 01:17 AM
ej_b16a's Avatar
Default which cams with stock B16a?
I want to put some more power out of mine b16a.
The engine only has 35k miles and no oil consumption so I don't want to take the head off, the cr will be 10.4 stock.
My aim is to get 200+ hp
The setup so far:
Jdm b16a (sirII) engine with stock p30 pistons
Itr Intake manifold (70 mm bored)
Skunk2 70 mm throttle body
3" Injen CAI
hondata intake gasket
Jdm dc sports 4-1 header 2.5 inch collector
2.5 inch testpipe
Invidia G200 catback (60 mm)
I will also get aftermarket camgears, valve springs and retainers. Tuning will be done with crome/ectune and plx wideband.
I want good midrange en peak power so I was thinking to get the skunk2 pro1 cams, but do you think these will be a good choise with this setup and stock cr? Or are there better cams for this setup?
Thanks
Old Mar 26, 2007 | 03:52 AM
EITCP's Avatar
Default Re: which cams with stock B16a? (ej_b16a)
for your compression i reccomend you either skunk stage1 or (if you want to have good midrange) buddy club III. You can also try ITR/CTR cams aswell. Your compression is way too low for pro1 cams
Old Mar 26, 2007 | 01:47 PM
sauceja's Avatar
Or just buy my ITR valvetrain (springs, retainers) and a set of gsr cams.
Will give you a good deal pm me.
Otherwise supertech valvetrain / skunk2 valve train and ITR cams or S2S1 or 2's.
Old Mar 26, 2007 | 02:09 PM
92TypeR's Avatar
FSAE
Default Re: which cams with stock B16a? (sauceja)
BC3+, Skunk2 Stage 1, TODA A, ITR. In that order.
Old Mar 26, 2007 | 11:36 PM
ej_b16a's Avatar
Thanx for the answers, I want something better than itr or ctr cams so I will get the buddyclub spec 3 plus or skunk2 stage 1 cams.
I will get aftermarket valve springs, but can I use itr retainers with the s2s1 or bc spec3+ and a rev limit of 9000 rpm.
thanx for the input!
Old Apr 2, 2007 | 06:26 PM
Dev15Bizz's Avatar
Default Re: (ej_b16a)
good luck getting 200 hp on a b16, 70mm TB is really big though... skunk 2 stage 1 cams are a good choice though
Old Apr 3, 2007 | 03:04 AM
gibsanez's Avatar
Default Re: (Dev15Bizz)
Reaching 200hp won't be the easiest thing, especially because you don't want to touch your pistons yet. That 70mm TB is actually slowing down your flow velocity and will make less horsepower than a smaller one on your 1.6.
Old Apr 3, 2007 | 05:07 AM
tartje's Avatar
its going to be very peaky, worse than a B16B, i hope thats the kind of characteristics you want from the engine
Old May 1, 2007 | 12:37 AM
ej_b16a's Avatar
I did some more research and with this cr and bolt-ons, I decided to go for s2s1's.
I know a guy that made 202 crank hp with these cams and similiar setup and the same guy is tuning my car. (He had only 10.2 cr, so I hope for a little more)
Modified by ej_b16a at 3:01 AM 5/1/2007
Old May 1, 2007 | 09:54 AM
doood's Avatar
been there done that
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ej_b16a &raquo;</TD></TR><TR><TD CLASS="quote">I did some more research and with this cr and bolt-ons, I decided to go for s2s1's.
Modified by ej_b16a at 3:01 AM 5/1/2007</TD></TR></TABLE>
200bhp and 200whp are two different things
Old May 1, 2007 | 02:06 PM
allnaturalb16's Avatar
Default Re: (doood)
bhp is braking hp an whp is wheel hp correct?
so what is bhp? or how is it figured?
Old May 1, 2007 | 04:01 PM
doood's Avatar
Default Re: (allnaturalb16)
bhp is base hp. same thing as crank hp. at least that's what i've been lead to believe.
Old May 1, 2007 | 04:09 PM
shrums-EG6's Avatar
whp is the actual hp you put down to the ground .
Old May 1, 2007 | 10:42 PM
ej_b16a's Avatar
Default Re: (doood)
I know, I was talking about crank hp. so I'm satisfied with 170+ whp
Old May 2, 2007 | 12:08 AM
cydal's Avatar
my friend has blok b's w/ blok spring/retainers and he's pushing 170 to the wheels
Old May 2, 2007 | 02:41 AM
salman's Avatar
Default Re: which cams with stock B16a? (cydal)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cydal &raquo;</TD></TR><TR><TD CLASS="quote">my friend has blok b's w/ blok spring/retainers and he's pushing 170 to the wheels</TD></TR></TABLE>
Setup?
Another_Si_Guy
17
Jan 7, 2016 07:34 AM
ej_b16a
18
Oct 19, 2007 01:04 PM
1quickvr4
May 9, 2005 12:16 PM
virginia_dude
Jan 30, 2004 05:05 AM
