Suspension & Brakes Theory, alignment, spring rates....
adjusting koni yellows
Old Mar 25, 2007 | 07:11 PM
ieatrice's Avatar
Default adjusting koni yellows
i'm on ots gc (koni specific) + koni yellows and the spring rates are 340f/250r. i have this set-up on my 96 civic hatchback. i heard you're suppose to set your shocks according to the spring rates. since the settings is 2 full turns from full soft-full stiff.. would i set the fronts 1.5 turns and the rears 1 turn? any help would be greatly appreciated. if anyone has the same setup on their ek, i'm curious to know what you're settings are too!
Old Mar 25, 2007 | 07:32 PM
ieatrice's Avatar
Default Re: adjusting koni yellows (bolsaman)
my fronts have the gc on the highest sleeve? is it normal to be that low with the coilovers set all the way up in the front?
Old Mar 26, 2007 | 12:20 PM
ieatrice's Avatar
heeeello?
Old Mar 26, 2007 | 01:20 PM
94eg!'s Avatar
#1 Super Guy
Loved
How much rebound damping you want is purely based on personal taste. It's like asking how much salt you should add to your french-fries. No one setting will "perform" that much better than another. The fastest setting is the one that lets the driver feel the most confident.
Also, there should be about 2.5 turns from full-soft to full-hard. I have my EG set on .75 from hard up front, and 1 or 1.5 from hard in the rear (400f/250r). The difference front & rear all depends on how much over & under-steer you are getting. If you can't track test your setup (I don't), just start out by driving them at both full soft & full hard so you can get a feel for the difference. Then you can find the middle ground that best suits you. Avoid having your rears set higher than the fronts (can cause over-steer) unless you really know what your doing...
Old Mar 26, 2007 | 01:22 PM
nonsense's Avatar
I'd start out with less turns and see how it rides. Maybe 1/2 turn form soft front and rear at first.
I'm not sure what you mean when you say they're set all the way up. Mine are on the lowest clip and set about 1/2 way up the threads and they don't seem all that low
JaDaM
Apr 13, 2010 08:43 AM
thanh4o8
Suspension & Brakes
Aug 15, 2009 11:33 AM
ieatrice
15
Mar 29, 2007 01:15 PM
ieatrice
Dec 15, 2006 07:06 PM
jli18
Suspension & Brakes
51
Nov 30, 2005 06:04 AM
