itr dash swap into eg
Old Mar 25, 2007 | 06:43 PM
eg6-crvtec65's Avatar
Default itr dash swap into eg
i bought my eg hatch with a fully itr interior swap it looks like to me all the wiring is done right but the cluster lights do not work all lights on the cluster such as signal lights and all of the warning lights (check engine) work but the back lights dont work so i cant see it at night any suggestions
Old Mar 25, 2007 | 07:15 PM
BlueIntegraBoy's Avatar
Default Re: itr dash swap into eg (eg6-crvtec65)
Check your instrument light fuse. Does your climate control lights work at all?
Old Mar 25, 2007 | 10:17 PM
Default Re: itr dash swap into eg (BlueIntegraBoy)
yeah the fuse is good and the climate control lights work
Old Mar 25, 2007 | 10:22 PM
Maybe the bulbs burnt out, or perhaps there's a short (not getting power from the fuse box).
Old Mar 26, 2007 | 06:47 AM
well i just bought a jdm cluster on ebay so ill see if it works because my cluster was in ruff shape
Old Mar 26, 2007 | 07:03 AM
boosted_ejcivic's Avatar
have you checked the dimmer switch?
Old Mar 26, 2007 | 08:44 PM
Default Re: (boosted_ejcivic)
yeah that was the first thing i checked
Old Mar 26, 2007 | 09:02 PM
Del_solution's Avatar
perhaps the guy who had it before installed aftermarket faces and disabled the lights. make sure the board hasnt been scrathed away from the light power. (seen this before in my friends Si coupe)
Old Mar 27, 2007 | 03:33 PM
Default Re: (Del_solution)
ok the other problems are clock and radio stopped working one day dont know why also i noticed that when i put the head lights on the intrument lights dim and the glove box light comes on
Old Mar 27, 2007 | 03:48 PM
StateOfMind's Avatar
Sounds like an electrical nightmare.
Old Mar 27, 2007 | 04:06 PM
Battle2.0Eg's Avatar
Default Re: (eg6-crvtec65)
Make sure your hazardous switch works, thats what will prevent the turn signals from working.
andrew.eg8
11
Sep 22, 2016 05:02 AM
hj2
Sep 9, 2009 07:18 AM
SPOOLINmatt
Mar 31, 2008 09:51 PM
HondaHemi
May 12, 2005 09:05 PM
jeef84
37
Feb 20, 2005 06:59 PM
